posted 12-06-2002 04:40 PM ET (US)
The chemical tie coat that serves as a primer to bind the bottom paint is light gray in color. You can try tapping an inconspicious spot with small, sharp chisel and remove a pice of the bottom paint for a look. Or, you can try a paint remover that is safe for fiberglass, in a small area and see how it works. The success of most paint removers hinges on the dwell time, that is the amount of time it is allowed to work, and the quantity that is applied.
I have used Peel Away (which requires up to 24 hours to work,) as well as Interlux paint stripper (which works faster, but is nastier) with very good results. But either way, it is a messy job. The only guarantee I make is that after you go through the trouble of removing antifoulant paint you will never apply it the way you did, i.e. thick and sloppy!
