ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Are Circuit Breakers Really Needed?
Author | Topic: Are Circuit Breakers Really Needed? |
bkoelbel |
posted 01-21-2003 07:25 AM ET (US)
I have an '86 20' Outrage, and the original wiring has a circuit breaker mounted near the transom on the starboard side. I've had several mechanics say that they're really not required, but I want to consult the forum before changing anything. I have 2 batteries (primary and back-up)supporting a mounted VHF, CD Player, Fishfinder, normal lighting, and ignition. Appreciate your thoughts, thanks. |
Dr T |
posted 01-21-2003 07:53 AM ET (US)
Well, you really don't need them if you don't care about frying all of your electronics on the same circuit and running the risk of fire if something shorts out. My 13 doesn't have any, but all I have are running lights and a fishfinder. If I want to work on anything, I just pull the battery cable. You are carrying a lot more power and complicated electronics around. The circuit breaker will also let you pull power without having to pull the battery cable. |
weekendwarrior |
posted 01-21-2003 09:17 AM ET (US)
I was taught that a circuit breaker or fuse should always be present no more than 12" from the battery on every wire connected to the battery. The main purpose is fire protection. Then every electrical component is individually fused for the protection of that particular component. |
triblet |
posted 01-21-2003 10:08 AM ET (US)
Dr T, short circuits trip breakers. Shorts don't fry electronics. A short in the wiring simply removes power from the electronics on the other end. Absent a CB or fuse, the wiring smokes a lot between the short and the battery but the electonics survive fine. Eevery circuit should have an
Tom W Clark |
posted 01-21-2003 10:19 AM ET (US)
bkoelbel, You've asked a loaded question. Is the circuit breaker mounted in the stern of your 1986 Outrage 20 required? No, it is not required. It is not required by the Coast Guard and it is not required by ABYC. It is not required to protect your electronics, as there is (or should be) another circuit breaker in the console guarding the electrical distribution panel and also every electrical device should have its own fuse or circuit breaker. Is the circuit breaker desirable? Yes it is. It protects the wiring run form the battery to the console. Without the circuit breaker, a short circuit could damage the wiring and start a fire. Is that very likely to happen? No, it is not, but it can and has. It’s really your call. If you have the circuit breaker, leave it alone. If you do not have one but want one, then install one. They’re not that intrusive. Can you get by without one? Yes, you can get by without one in that location as all Whalers did up until the mid 1980’s, but you will be somewhat less protected. |
dreid |
posted 01-21-2003 10:43 AM ET (US)
A benefit not touched on by the others here, I like being able to "turn off" the boat with that one breaker located aft, near the batteries. Without it, and you could easily leave on a fishfinder, gps or something else to drain your batteries over night. If re-wiring, make sure the main lead going to the console remains wired through that breaker, and you'll retain that benefit as well as reduce the chance of fried wiring or worse. |
bkoelbel |
posted 01-21-2003 11:32 AM ET (US)
Well, I am certainly glad I asked! If 'desired' = smart, I'm all over retaining the original wiring. Makes me very suspicious of my mechanic now.....thanks for the feedback. |
ratherwhalering |
posted 01-21-2003 01:30 PM ET (US)
I always try to remember to trip my circut breaker when I leave the boat, not only to protect the battery against unintentional discharge, but also because my kill switch and ignition is wired to the console breaker; the engine will turn over, but not start when the circut is open. I figure it may prevent theft, or joy riding, someday. It just takes me a few cranks to remember to reset the thing again! |
mtbadfish |
posted 01-21-2003 03:34 PM ET (US)
I haven't come across a breaker in the console on my boat, but the one in the stern had been removed by the previous owner, evidently when the batteries were relocated to the console (cleaner looking stern, but a pain to work with). Were there breakers in all consoles('89 Outrage)? How involved is it to install one? Thanks, |
ratherwhalering |
posted 01-21-2003 06:11 PM ET (US)
Perhaps I used the wrong term. My switch is stock Whaler, located in the starbord stern quarter. There is a push/pull black button mounted to a plastic cover, and it is the main switch for the buss bar located in the console. I thought this was a circut breaker, is that correct? (All other electronics and accessories have in-line fuses too) |
triblet |
posted 01-21-2003 10:37 PM ET (US)
mtbadfish, you don't need a master breaker in the console if battery is in the console, the individual circuits have breakers or fuses, and the run from those individual breakers or fuses to the battery is short. A master breaker would only be helpful if it Note that all wiring from the master breaker
Roscoe |
posted 01-22-2003 02:24 AM ET (US)
Note * Circuit breakers are not to be used as switches.They are sensitive circuit protection(expensive fuses). Using as a switch can easily cause damage to the breaker unit. |
dfmcintyre |
posted 01-22-2003 09:15 AM ET (US)
I thought it was ok to use cb's as switches. Someone should tell the folks over at Tiara, as they've been installing cb panels to be used as switches for at least a decade. Don |
Tom W Clark |
posted 01-22-2003 10:58 AM ET (US)
Mike Hayden, I just looked at the exploded parts diagram for the 1986 Standard Console and I found no circuit breaker shown at the console, though the circuit breaker is shown in the rear of the boat. I think I made a false assumption. On my 1983 Outrage 18 there was a large circuit breaker mounted immediately above the front console door inside the console. It was mounted to a short piece of aluminum angle so you could simply reach up there and switch it. My assumption was that when Whaler added a circuit breaker in the stern it was to supplement the protection afforded by this breaker. I now suppose Whaler simply moved the circuit breaker to protect a greater portion of the wiring run, which makes some sense. Until the late 1980's I do not think the Montauk even had a circuit breaker at all, but instead simply had the fuses protecting the individual electrical devices. As time progressed, two things happened. One: more and more electrical demands were (and are) being placed on the boats electrical distribution system as fish finders, navigation gear, radios, ect became increasingly popular. As an example of how simple early Whaler wiring was, consider the factory optional bilge pump offered in the 1960's. All it had was a two pronged pig tail that you plugged into the lead for the stern light when you wanted to use it. You would turn it on and off with the light switch. The other thing that has happened is that everybody including boat manufacturers are going to greater and greater lengths to make things safe and idiot proof. While a worthy goal, making something idiot proof is just about impossible. It is true that the circuit breakers in your home really should not be used as switches with any sort of regularity, but they are routinely used as such on boats. |
triblet |
posted 01-22-2003 11:01 AM ET (US)
Some circuit breakers are designed to be used as switches, other are not. Check the specs.
mtbadfish |
posted 01-22-2003 11:50 AM ET (US)
Tom and Chuck, Thanks for the info, I was thinking about pulling up the cover and taking another look in the console. My dad's 20' Outrage had the breaker in the stern and mine has the cover but the breaker is gone and the wires bolted together. I quess I'll check the lines going to the motor and the trim pump to make sure they are adequately protected in the console though. I've got such a misch mash of wiring in the console it scares me. It'll be interesting to see what it takes to straighten it out. I contacted the local Whaler dealer and made tentative plans to have them take care of the more technical aspects of the job. Just have to get my end done first. Thanks again, |
dburton |
posted 01-22-2003 11:04 PM ET (US)
I have a 1986 18 Outrage with a master circuit breaker on the stern. About 6 months after I bought her I discovered that all my power at the console wouldn’t work. This was my first boat, so I was pretty clueless. Anyway, something, maybe me, caused the master circuit breaker to open. Because of the -corrosion of the salt water environment the switch would not close. Luckily I made my discovery on-shore and replacing the breaker was no big deal but cost around $35-$40. My point is, that if your breaker is original, it may be a good idea to check that it is holding up well. If you are out on the water and you are unable to reset the breaker it could be the start of a bad day. Doug |
triblet |
posted 01-23-2003 12:47 AM ET (US)
If you can't reset it, and you're sure you don't have a short, hot wire it. Put a penny in, so to speak: Turn everything off, or, better, unplug it. If there were big sparks, you do have a short, I know, easy for YOU to say, Chuck, you're
Whalerdan |
posted 01-23-2003 12:06 PM ET (US)
I wouldn't do it that way! Just disconnect the leads on the breaker. If it dosen't hold with no wires on it, it's probably bad. THEN do what Chuck saids. |
triblet |
posted 01-23-2003 07:57 PM ET (US)
whalerdan, you are absolutely right. DUH. The good news is I can go diving this weekend.
lhg |
posted 01-23-2003 08:06 PM ET (US)
The Whaler Outrage/Revenge circuit breaker used in the 1986 and later second generation boats, is a hard item to find for replacement. If one has an older boat, bought used, it's entirely possible the original one corroded or failed, and some other non-factory replacement was made. One of mine had to be replaced, and only the factory had it. They are not designed to be used as switches, since they are the pop-up variety. It is not a push-pull button. Mine cost $75 from BW about 12 years ago! I still don't know who made them, or where to find one if needed. The boat catalogs do not show it anywhere. Anybody know? Post in OEM section please. On my '86 and '89 boats, these are 50 amp, and the only breaker on the boat. Then, there are fuses to every single electrical accessory, including nav lights, in the console, or in-line for a few pumps connected directly with battery leads. I was always under the assumption that this starboard stern corner mounted breaker was required by codes, for fire prevention. Most boat fires are electrical in origin, including static electricity. The fuses protect your electronics, but the breaker protects you from fire, especially since the heavy gauge leads up to the control station/console are in the tunnel, near the fuel tank and possible leaking fuel tank fumes. Note: I think this stern mounted breaker could have been a new change in 1986 or slightly earlier. My Owners manual indicates, incorrectly for 86 models, that the breaker was in the console. It is not, as described above. That seems to be a bad idea, since it was too far from the battery. Hence the newer design immediately adjacent to the battery location, which protects the long run to the console. |
Scirocco |
posted 01-23-2003 09:44 PM ET (US)
this evening i was re-wiring the center console in my 82 montauk and i was wondering what to do about replacing the factory 30A circuit breaker. i was planning on just re-using the original breaker but that idea fell apart when the breaker shattered in my hand as i was disconnecting it from the instrament panel. the breaker looks like it was made by AMF. i just finished surfing the net for replacements and here's what i found. http://www.cmsquick.com/prod_24_W1.html[/url] there's no price listed so i'll have to call tomorrow. it looks like a good match. they even have a replacement boot. one question... |
Scirocco |
posted 01-23-2003 09:45 PM ET (US)
sorry about that first link http://www.cmsquick.com/prod_24_W1.html |
Knockerjoe |
posted 01-23-2003 09:46 PM ET (US)
The aft starboard breaker is an aviation type cuircuit breaker. If you need one check out aviation supply type places like this http://www.ti.com/snc/products/controls/acb.htm Problem is that aviation stuff is usually more expensive than marine! |
