  GPS Chartplotter/Conquest 23 installation
Author Topic:   GPS Chartplotter/Conquest 23 installation
paulgeb posted 03-26-2003 09:01 AM ET (US)   Profile for paulgeb   Send Email to paulgeb
I am going to install a standard horizon gps chartplotter in my BW Conquest 23. Can anyone let me know the proper way to wire the power to the unit.
Thanks so much......Paul
Offshore20 posted 03-27-2003 10:14 PM ET (US)     Profile for Offshore20  Send Email to Offshore20
Paul:
Look at www.thehulltruth.com There are some real good tech guy's on that site.
Offshore20
TRAFFICLAWYER posted 03-28-2003 08:00 AM ET (US)     Profile for TRAFFICLAWYER
i have a cp170 it is wired to the acc. switch.
aubv posted 03-28-2003 03:34 PM ET (US)     Profile for aubv  Send Email to aubv
Paulgeb,
Red=postive Black = Negative
So a black wire from the GPS should go to a common negative bus bar and a red wire should go to a common positive bus bar readily identifiable under/behind your console. (one should have a fairly stout red wire the other a fairly stout black wire. Personally I'd use ring terminal crimp-ons and heat shrink tubing. When mounting a chart plotter/FF I used an accessory rocker switch also. While it is not required as the unit has an on/off button, I preferred this method. I believe Whaler builds boats with positive (red) already supplied to the rocker switches. So if you want to use a rocker switch then you would still run the black wire to the common negative buss and the red to an upper position on the rocker switch.
More important, where/how are you going to mount the unit?
