Topic: Gas Cap Chain Fell in Gas Tank
Homerun04 |
posted 04-13-2003 06:53 AM ET (US)
Okay....here's a strange one (I think). I have a 1994 Whaler 19' Outrage with a 70 gallon gas tank. The gas cap to the tank has a safety chain on the cap so that you do not lose the cap. Well, late last season, when I was filling up the tank, the chain snapped off and fell back into my gas tank.How does one remove a piece of chain from the gas tank? I can't imagine this is a good thing to have in my tank. Thanks folks.
posted 04-13-2003 09:38 AM ET (US)
Typically the chain is secured to the cap and to the fill fitting. How did it break away from both of them?Where do you think the chain has landed? In the filler hose? There might have been enough flow to push it along and into the tank when pumping in gasoline. Can take off the access plate on the tank? Is the tank baffled? It might be hard to find. Is the chain magnetic? You might be able to fish for it with a small magnet. Don't loose the magnet! |
triblet
posted 04-13-2003 10:31 AM ET (US)
It's probably not going to hurt anything in there. At least on my Pate, there's a screen over the end of the intake, so it's not going to migrate to the engine. IF it's magnetic (I suspect it isn't), jimh's magnet ides will probably, work, provided the tank isn't magnetic too (unlikely, IIRC they are aluminium.).You might also try to get it out with a pick-up tool -- one of those gizmos where you push a plunger on one end, and four wire jaws open on the other end. Chuck
Jerry Townsend
posted 04-13-2003 11:45 AM ET (US)
HomeRun04 - I wouldn' worry about it. It can't really hurt anything - unless it could get into the feed line to the engine. As Chuck points out, typically there is a screen on the feed line. Further, your tank is baffled - meaning that the tank is configured like a house with a few walls. Chances are the small piece of chain is resting against one of those baffles and it will not move from that point. ---- Jerry/Idaho |
Sal DiMercurio
posted 04-13-2003 12:07 PM ET (US)
Don't even worry about it. Number 1, it can't hurt a thing, number 2, you couldn't fish it out even if you had to. Forget about it & put a new one on. Sal |
doobee
posted 04-23-2003 10:37 PM ET (US)
Could cause a chain reaction!) |
