ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods GROUND FOR INTERNAL GAS TANK
Author | Topic: GROUND FOR INTERNAL GAS TANK |
Bear |
posted 04-14-2003 12:57 PM ET (US)
I'm in the final stages of putting the gas tank back in my 88 20' Outrage and am replacing the ground that goes from the aft part of the tank to a bronze/brass circular disk mounted on the stern below the waterline. I need to replace the circular disk.....anybody have any idea where I may be able to find a replacement??? Thanks... |
Gep |
posted 04-14-2003 01:23 PM ET (US)
You can obtain a bronze grouning plate from Sea Island Marine in North Carolina. I looked for the paperwork when I got mine and can't find it anymore. Maybe Kingfish still has this info. Mike |
JOHN W MAYO |
posted 04-14-2003 01:48 PM ET (US)
That circular disk you are talking about, I have one on my transom, below the water line, right side. I have never know what it was for, is that the disk you are saying is a grounding disk? |
mustang7nh |
posted 04-14-2003 03:43 PM ET (US)
I have an 88 also 20OR. When I took of the speedo and fishfinder that didn't work from teh guy I bought it from, I assumed this was some sort of transducer. I ripped it off and cut the wire where it passed through the transom. Is this a safety hazard? |
Bear |
posted 04-14-2003 03:47 PM ET (US)
Yep...closest I can deduct from previous threads on this site, as well as what I've found from essentially taking my whole whaler apart, is the ground path is green wire from fill on port side to attachment point where fill enters the tank. From there is goes through skin of tank to next green wire attachment points at circular plate where the fuel hoses attach. Green wire goes from there to circular disk under water line. After 15 yrs, disk is toast, needs replacing. |
kingfish |
posted 04-14-2003 06:38 PM ET (US)
Sea Island Marine, Beaufort, *South Carolina* |
Bear |
posted 04-15-2003 09:52 AM ET (US)
Have contacted Sea Island and they will ship the disk shortly. Thanks again to all for your help! |
myotherboatisawhaler |
posted 04-16-2003 06:16 AM ET (US)
just added an internal aluminum fuel tank inside the console of my 84 montauk with the fill and vent through the side of the console. grounded the tank to my main ground bus. do i need to ground it at the fill through the hull to an under water bronze disk as discribed by bear? also disc are available at morehead marine in morehead city north carolina. saw them last weekend while rumaging through inventory of whaler parts. |
posted 04-16-2003 09:12 AM ET (US)
I believe the current practice at Boston Whaler is to bond the fuel system to the battery negative. I don't see the round bronze electrode on the transom of the newer boats. |
posted 05-25-2003 04:05 PM ET (US)
This recently added picture in CETACEA shows the electrode being discussed in this article thread: http://continuouswave.com/whaler/cetacea/cetaceaPage73.html#73-01 |
