Topic: outrage 18 questions
vineyarder |
posted 04-22-2003 01:02 PM ET (US)
Am working on a 1987 Outrage 18 that I purchased over the winter. I am in need of a replacement stern light - the holder is there, the post and light are not. The circuit breaker/switch and plastic box are history. Also need a new console windshield. Does any body know who carries this stuff? Thanks in advance for any suggestions/help.
gvisko
posted 04-22-2003 06:39 PM ET (US)
I have the light off my 83 outrage which I don't use gvisko |
lhg
posted 04-22-2003 07:39 PM ET (US)
There is previous discussion on putting together a new stern light pole. the light on top of it is by Perko. Try a search, and look through the OEM section. The 50 amp circuit is hard to come by. Try Whaler, as they must be using something similar in the commercial division for the 19 Guardian. OEM section also has info on the windshield, which is the same as a Montauk. |
vineyarder
posted 04-23-2003 02:59 PM ET (US)
Thanks for the info. Gvisko I would be interested in your light. I dug through the previous posts and did some further research. Spar Tech 321-636-7562 makes replacement windshields (about 100 bucks). I found the fuse switch (made by ETA of Germany) at www.e-sonic.com. |
posted 04-23-2003 08:51 PM ET (US)
vineyarder,Thank you very much for posting a follow-up with the information you found in your search of the archives. That is an excellent thing to do, and your example should inspire more people with questions to post their findings when they finally discover the answer. Thanks again, --jimh
ewalsh
posted 04-24-2003 08:14 AM ET (US)
Vine,I have a spare fusebox from a 1988 Outrage. If interested, I'll check out its condition. Ed |
ewalsh
posted 04-24-2003 08:15 AM ET (US)
Let me clarify.I have a spare circuit breaker/switch and plastic box from a 1988 Outrage. If interested, I'll check out its condition. Ed
andygere
posted 04-24-2003 09:05 AM ET (US)
Ed, If it is servicable, I would be interested in buying your circuit breaker assembly. |
vineyarder
posted 04-24-2003 01:39 PM ET (US)
Am interested in the fuse box. Let me know. generalsurgery@yahoo.com. thanks. |
ewalsh
posted 04-24-2003 08:22 PM ET (US)
Here is a picture of the breaker:www.briefcase.yahoo.com/rundeep_32 Look at pics: Breaker, Breaker1, Breaker2. There is a little stain from Cetol teak oil on the cover itself. I'm sure it can be removed with a little elbow grease. Everything else from the wiring to the switch itself looks great. Make me an offer? Regards, Ed |
vineyarder
posted 04-25-2003 12:33 PM ET (US)
Ed - I'll give you 10 bucks plus shipping. Let me know. Generalsurgery@yahoo.com. Thanks. |
