  fuel filters
Author Topic:   fuel filters
Bertramp posted 06-12-2003 10:17 AM ET (US)   Profile for Bertramp   Send Email to Bertramp
I am in the process of installing a canister style fuel filter. How do most of you that use them have 'em plumbed ? I was thinking of setting it up so that I can use my fuel hose direct to tank or through the filter (ie... a male plug to go in to at either source. comments please.
where2 posted 06-12-2003 12:46 PM ET (US)     Profile for where2  Send Email to where2
If it were me, I'd put a male-male hose barb in my toolbox, and use all-SS hose clamps on the fuel lines. Then I could hard plumb it, and have the parts to reroute it if I had to. I've had too many leaky connections with quick-connect fittings. Things bump them and pop them off at the worst times...
lhg posted 06-12-2003 07:44 PM ET (US)     Profile for lhg
For whatever reason you would want to bypass the water separating fuel filter, which I can't imagine (it's easy to simply carry a spare $7 filter), you could use one of Tempo's two way selector valves before the filter and plumb it permanently. One leg goes into the filter, the other to a separate gas line. You would need two primer bulbs and engine connectors with this setup.
Bertramp posted 06-13-2003 09:55 AM ET (US)     Profile for Bertramp  Send Email to Bertramp
sounds like the best alternative is what you both suggested ... a spare barbed fitting and a spare filter canister. (belt and suspenders) ... thanks
