Topic: best sealant for wet screws
sr |
posted 06-24-2003 10:29 PM ET (US)
O.K. I've searched, I've shopped and bought 5200 and am now ready to affix my transducer. Then I read some more. Is caulk or the sealant better? When I cleaned up the mess the dealer/rigger did (silicon) I know that is not the anwser. I did also check the archives via search. sr
doobee
posted 06-24-2003 11:03 PM ET (US)
I would recommend that you use 3M 4200, or Boatlife Lifecaulk. Both are suitable for below the waterline. |
simonmeridew
posted 06-27-2003 07:40 AM ET (US)
I'd second the 4200 idea; when I was scanning topics and saw this one I thought back to when I was "firming up" loose screws for my Montauk's railing. I used "Gorilla Glue" which isn't good for woodworking but great for "wet wood" not that I have any or at least admit to. I think it's very similar to 5200, a kind of polyurethane; expands like 2-3 times as it cures. Back to the topic: 4200 simonmeridew |
sr
posted 06-27-2003 08:24 PM ET (US)
I appreciate the info, thank you! Unfortunately living in a small town I rely on my Ace Hardware guy. They can order either of the products and when I looked over his shoulder the listing for 4200 said" same as 5200, but 1/2 as strong". This is good in case I need to slightly modify the angle of transducer. Now things have to get ugly, because the drilling comes next! sr |
simonmeridew
posted 06-28-2003 06:43 PM ET (US)
OK sr I located what I consider THE technical manual on marine sealants. Way more than you want to know but it will guide you in your purchase. I went with 3M 4200. http://www.bosunsupplies.com/Sealants.cfmsimonmeridew |
JOHN W MAYO
posted 06-30-2003 08:57 AM ET (US)
I used the 4200 myself, I am going to use it today to secure the 4 bolts to mount one of those heavy duty dive ladders use to the transom. I just hate to drill those holes...,It is almost painfull to me to do that to my Whaler |
OutrageMan
posted 06-30-2003 09:32 AM ET (US)
I hate to throw a monkey wrench in the works, but I would forgo the 4200 for 3M 101. Being a polysulfide it cures in the presence of moisture. Great for below the waterline. More resilancy than 4200 or 5200.Brian |
kingfish
posted 06-30-2003 09:38 AM ET (US)
Brian-I'm happy to take your word that 101 has more resiliency than 4200 or 5200; I've never used 101 so I don't have any first hand knowledge. Be aware though, that 4200 and 5200 both cure underwater too, and I've never had a resiliency problem with either one. I'll get my hands on some 101 and give it a try- John |
Gene in NC
posted 07-02-2003 10:24 AM ET (US)
Sc, you don't have to limited to small town resources. With the net you live in a very small world. Any and every thing is available w/o unreasonable effort or cost. Sealants are different from adhesives like 3m 5200. If only selant is needed prob best to avoid adhesives. |
