  96 Montauk seat mount coming out of floor
Author Topic:   96 Montauk seat mount coming out of floor
Bayouwhaler posted 07-07-2003 09:55 AM ET (US)   Profile for Bayouwhaler   Send Email to Bayouwhaler
I have converted my seat seat mount on the Montauk to hold a 94 quart Igloo to use as a fish box. The fish box works great but the screws on the seat mount are coming out of the floor. Has anyone had the screws come out of the floor on their montauk? Does anyone have a solution for this?
whalerajm posted 07-07-2003 06:37 PM ET (US)     Profile for whalerajm  Send Email to whalerajm
I have a 1975 Montauk...All screws in fiberglass were loose loose.
Solution...Remove screw, fill with wood glue and/or contact cement insert wood dowel (chopsticks work)(suggest tight fit with tapered end on point of entry)...Let glue set...drill guide hole and replace screw.
lhg posted 07-07-2003 07:40 PM ET (US)     Profile for lhg
As long as the screw hole will be covered by the fitting it is attaching, you can drill it out to about 3/8" and pack and fill the enlarged hole with white Marine-Tex epoxy paste, the re-drill for self tapping screws. Your problems will be over permanently. Marine Tex works well because it not only will prevent moisture from getting to the wood floor backing, but bonds well to both the glass and the plywood.
