Topic: Sloppy hydraulic steering
alkar |
posted 07-07-2003 01:05 PM ET (US)
I recently replaced my Seastar pump with a newer, higher-volume pump. I made the switch because the only pump took over five turns to go from lock to lock. The newer pump, the 5.4, was supposed to go lock to lock in about 3.6 turns, so I upgraded instead of investing the money to rebuild the old pump (which had started to slip). When we were bleeding the system I noticed that one of the little allen-head bleeder screws had started to strip. It will still tighten - but not to the point where it stops completely. Since the bleeder screw was secure, and it did not appear to be leaking, I took the boat on a fishing trip. Over the course of the weekend the steering became increasingly sloppy. Now I feel considerable slipping & skipping as I turn the wheel. There is no sign of leaking hydraulic fluid at the helm or at the cylinder aft, and the problem screw is still snug (although it's easy to turn with an allen wrench). The visible portions of the hoses look like new. I'm guessing that the screw is gradually allowing air to sneak in to the system. Any thoughts? If the screw is stripped, I'd need to tap the hole for the next size up and replace it. Any downside to doing this? Any other possible problems/solutions?
Duckin Whalers
posted 07-07-2003 01:13 PM ET (US)
Somebody help me with the name of the stuff,,,,,,,,The white thin tape to wrap fuel fittings and the like. Ahh,,,,, teflon tape around the fitting? I had my fuel lines leaking a little until I used the teflon tape. It seals the fittings while preventing and foreign material from entering the system. Good to use in place of locktite ect. on things like break lines and has good heat resistant qualities. Although, I'm not sure that a hydraulic steering pump is the proper application. I have been assuming you have been working hard on your green machine or out using it, hopefully using it,I was hoping to see some pictures of it on the water soon. Hows the fishing?....Paul |
tomroe
posted 07-07-2003 01:57 PM ET (US)
I think you got it, it's teflon tape. I would use it in paste form though. I have seen the teflon tape get into hydraulic systems (in non-marine applications) and cause blockages. I think Loc-Tite also makes a sealant just for hydraulic systems. I also think somebody, probably Loc-Tite, makes a thread repair epoxy. |
kingfish
posted 07-07-2003 02:01 PM ET (US)
Alex-What you are describing could be air having gotten back into the system, but it also acts "sloppy" if the fluid level is simply low. If you can't find any evidence around the bleeder valve of loose fluid, I'd suspect you never got your system completely bled. Those bleeder valves are threaded against an O-ring to develop a seal; you might want to pull the valves all the way out and inspect them for good O-rings. I'm not too sure teflon will get you where you want to go, but it might. Be sure to use teflon tape for petroleum products if you go that route, and be careful you don't lose any of it into your hydraulic system. Those threads are straight machine threads, not tapered pipe threads; I would wonder if you couldn't heli-coil an over size hole back to the original bleeder valve size if it is the female thread that is bad (and I assume it is as the valve is stainless). John |
alkar
posted 07-07-2003 02:05 PM ET (US)
I was worried about using a tape or other sealants because the screw needs to be run in and out multiple times whenever the system is purged. I'm concerned that little bits and pieces of the sealing material could be introduced to the system each time the screw is losened and tightened. I'm also worried that it will be a very temporary fix and I want to do it right.It there a downside to tapping for a screw one size up and then fluhsing the oil out through the hole to make sure nothing is left behind? More importantly, do you guys think I have properly identified the problem? Are there other potential explanations for the deterioration in the steering? |
kingfish
posted 07-07-2003 04:27 PM ET (US)
Alex-Are you working from a written set of directions when you bleed your system? There is a specified procedure and a definite order in which each step of the procedure must be taken. Let me know if you'd like me to scan my Seastar bleeding directions and e-mail them to you. I would be concerned that without a bleed valve nipple that you can attach clear tubing to in order to see when the bubbles are gone, it would be difficult to keep from introducing air back into the system when you screw a simple machine screw back in. John |
alkar
posted 07-07-2003 06:22 PM ET (US)
John,I didn't see your first response before sending my last, so I was off the mark even more than usual. I do have the Sea Star written instructions. They include directions for systems like mine. (My system came without the bleeder nipples). I followed the instructions to the extent that I could, but I had a kid for a helper, and I'm not certain he was able to apply enough resistance to the steering shaft during the purging process. The steering wasn't perfectly smooth when I was finished with the installation, but it was wonderful compared to it's present condition. I assume that the steering would not degrade through use if it was not either losing fluid or introducing new air. Is that a correct assumption? I think it would be nice to retro-fit the bleeder nipples. Anybody ever done that? |
acseatsri
posted 07-07-2003 06:42 PM ET (US)
If the screw won't tighten, it HAS to be leaking. If it is slipping/skipping, it's because air is being pumped into the system as fluid escapes thru the loose screw and the reservoir empties. You're probably steering more on the build-up of air pressure now than you are hydraulic fluid. I believe I read somewhere that the pressure generated is in excess of 500 lbs per square inch. I thought the relief valve setting is 750-800 lbs. It should be on the teleflex website. |
lhg
posted 07-07-2003 07:44 PM ET (US)
As Kingfish says, it sounds like an improper bleed job. If fluid is not getting out, air is not getting in. All of this, of course, assumes the engine cylinder is not worn out and in need of a re-build. |
alkar
posted 07-07-2003 08:41 PM ET (US)
Larry, are the symptoms I described consistent with a cylinder in need of repair? Are there diagnotic tests I could perform to clearly identify the problem? If it was nothing more than an improper bleed job why would the condition worsen over time? |
diamondjj
posted 07-07-2003 09:37 PM ET (US)
You DO NOT use teflon tape on any Seastar hydraulic fitting from Teleflex. There is a techical bulletin issued by them dated 05/02/2002 regarding re-orienting the elbow fittings on their units and they state not to use teflon tape. http://www.seastarsteering.com/SITE_MAP/s_map.htm If any pieces of that tape gets into your system, it can cause all sorts of problems. They recommend using liquid teflon (permatex makes it) instead, but if you use it, you have to make sure that none of it is exposed inside the system that can break off. I believe it is loc-tite makes a hydraulic thread sealant that is better than liquid teflon but more expensive , which is what I use. The bleeder screws have o-rings and should not require a sealant, so they may be stripped. You can try the loc-tite product and let it set to see if it helps but you may wind up having to re-tap the bleeders (let's hope not). |
Duckin Whalers
posted 07-07-2003 10:57 PM ET (US)
Like I said, I was unsure about the usage of teflon tape with a steering stystem. I know from rebuiding hydraulic implements that teflon tape is the prefered method of sealing small bleeder valves. (classic car restorations too,brakes in particular)I think the person using it has to have enough common sence not to wrap the fitting to far. If you wrap the fitting to the bottom of the machine threads you will obviously interject foreign material into the system. That is a no-no. If, your bleeder valve is leaking and you can positively isolate that leak, teflon tape at the top of the machine thread will probably fix your problem. If, you are unsure about your bleeding procedure you should maybe think about just bleeding the system again. Teflon tape is harmless when used properly and CANNOT get into any brake/hydralic lines when used accordingly. The liquid teflon, from my experience is exactly the opposite. I will not use it with any vehicle/implement lines. |
tomroe
posted 07-08-2003 07:10 AM ET (US)
Loc-Tite does make a liquid thread sealant for specifically for hydraulic systems, it won't foul anything if introduced into the system. I'm curious why any type of thread sealant/thread lock would be used on brake lines. Most brake lines I have seen have inverted flare fittings which don't rely on the threads to do any sealing. It seems that an anti-seize would be a better product to use. |
alkar
posted 07-08-2003 10:55 AM ET (US)
Before I move ahead with repair I'd like to make sure I'm correctly diagnosing the problem. I have about 20 hours on the boat since I installed the new hydraulic pump. The steering is gradually becoming less and less responsive. I can feel larger slips in the wheel as I turn it now, so she's on the trailer until I get this properly fixed. 1) Doesn't the worsening condition suggest a leak of some kind? (As opposed to inadequate bleeding the system twenty hours ago.) 2) How does a hydraulic steering system behave when the cylinder needs to be rebuilt? Is there some sort of diagnostic test I can perform to determine if my cylinder is Okay? 3) Is it possible to tap the cylinder and retrofit some type of hydraulic bleeder valve? Thanks for your help guys. Alex |
diamondjj
posted 07-08-2003 11:50 AM ET (US)
alkar,Regarding questions : (1) If you were leaking hydraulic fluid, you would see it somewhere on the outside of the cylinder,either around the stainless shaft or around the bleeder screw (allen fitting). Are you adding fluid at the helm periodically ? If you are, check inside the console to see if the fittings are leaking around the helm pump. If you are not adding fluid then you probably do not have an external leak, but something internal at the cylinder. Most of the newer seastar cylinders from teleflex have bleeder screws (nuts) where you open them with a wrench. How old is your cylinder ? Some of the older designs with allen fittings are not rebuildable and you may have to buy a new one. If you can describe what the cylinder looks like or e-mail a picture, I might be able to tell. I replaced the helm pump on my friend's boat and I warned him that his old cylinder (with the allen head bleeders) may not be able to take the added pressure from the new pump which happened later. He had the old style which was not rebuildable(no kits available), so I put a new one in for him. (2) Since the condition seems to be worsening over time and assuming that you are not adding fluid at the helm, with no visible signs of fluid on the outside around the shafts and the bleeder screw, it is possible that the internal seals are shot inside the cylinder, similar to what happened to my friend. Try rebleeding the system and see if the steering improves. When bleeding, make sure the helm is full and open the bleeder, then slowly turn the wheel in the appropriate direction until it stops but do not force it. Close the bleeder and repeat the process in the opposite direction with the other bleeder screw open, making sure that you keep the helm full at all times, otherwise you will introduce air in the system. If you still have the problem, you may want to contact the Teleflex Hydraulic Division up in Canada and tell them your symptoms. They will also be able to tell you if your cylinder is rebuildable. (3) The bleeder screws on the newer units have o-rings. You will have to match a retrofitted bleeder screw with one that exactly matches the internal profile of the one you are replacing. This, I have never had to do, thankfully. |
kingfish
posted 07-08-2003 11:55 AM ET (US)
Alex-I'll answer the part(s) of your questions that I can- The worsening needs to be accompanied by some evidence of fluid leakage somewhere in order to be something *other* than either inadequate initial bleed or failing cylinder seals. There are only so many spots leakage can occur, and I should think you would easily be able to physically look at each one and see if there is any hydraulic fluid showing up. If air is coming in, fluid is going out. I don't know how hydraulic steering acts when the cylinder needs rebuilding or replacing, but I would expect that it would act "lazy", that is you wouldn't get a one-to-one ratio of turning the wheel to turning the engine; when you come to the end of the motor's travel in one or both directions, I'd think you'd still be able to turn the wheel, but probably with more effort than when within the motor's travel. I should think with proper care you could retap the cylinder, but I will bow to higher levels of expertise on this one. As you have already stated, the concern would be keeping the drillings etc. from contaminating the cylinder. What do you have at your bleeding fittings now? Is it just an allen head screw, so when you remove one any fluid that comes out just runs down the surface of the cylinder? Are they inset with a shoulder and O-ring seal? John |
alkar
posted 07-08-2003 12:59 PM ET (US)
Thanks guys. I'm learning with each return post.My fittings are simple allen-head machine screws. There are no nipples, and they have no o-rings. When I bleed the system the fluid does just drain/squirt out the hole. I do not know how old the system is. The portion of the hose that is visible inside the console looks shiny and new, but the pump I replaced looked pretty old. The Honda motors are 2000 model year, but the steering system may well predate them. On my next break I'm going to price a new cylinder... ouch...again. Alex |
diamondjj
posted 07-08-2003 02:17 PM ET (US)
Alkar, May run you between four and five hundred. Check out surplus unlimited for cylinders, rebuild kits, and prices. www.surplusunlimited.com
diamondjj
posted 07-08-2003 02:38 PM ET (US)
alkar, before you start spending some serious dough on a new cylinder, try re-bleeding the system and also see if there is a rebuild kit available for your particular unit if needed. As I mentioned earlier, there are no rebuild kits available for some of the older model cylinders with allen head bleeders. The kits if available,can run from about $30.00 to $80.00 depending on the unit. |
lhg
posted 07-08-2003 03:59 PM ET (US)
Alex - If it is your cylinder and you need a new one, with the twin engine installation on the WD, you should use a SIDE MOUNT cylinder, installed through the tilt tube BETWEEN the engines, and using a "steersman" lube fitting on the ram end. See the Reference section for information on this installation, which I use quite successfully on my 18. This is much cleaner than a front mount cylinder. The Side mount cylinder is about $160 less, also. (about $260)I am also wondering if your higher capacity helm pump, resulting in the fewer wheel turns, is the problem with the older cylinder. That system is really only recommended for high speed installations. On my 25 Outrage, I use twin side mount cylinders and the Sea Star II helm pump. Because of tilt clearance, all WD's came factory equipped with side mount cylinders. |
alkar
posted 07-08-2003 04:05 PM ET (US)
Thanks diamondjj. I'm planning to get the information off of the cylinder tonight so I can describe what I have more precisely. In the event I need a new cylinder I'll probably install it myself. Is that an idiot-proof job? How long should the job take? |
Backlash
posted 07-08-2003 05:43 PM ET (US)
Alex,All excellent information above. The first thing I would check is the fluid level in the helm pump. It should be within a 1/4" of the top. If not, then you probably have a leak somewhere, assuming it was full when the initial bleeding was done. My bleed screws are the same 5mm allen head with no seals or 0-rings. Both had been leaking slightly and when I installed a 20 degree wedge at the pump I used the Loc-Tite hydraulic thread sealant on the screws AFTER threading them in part way. No more leaks. Teleflex recommends completely removing the bleeder screws rather than just loosening them when bleeding the system. Steve |
diamondjj
posted 07-08-2003 06:13 PM ET (US)
Alex, I was looking at the pictures of your rig that you posted earlier, specifically the one of your whaler drive but I could not see enough of your cylinder to identify it. If you have to replace the unit, you might want to consider lhg's recommendation for twin engine installations. If you get a new cylinder, make sure you match the new cylinder with your new helm (Pro model ?). If you are turning 3.6 total, I believe you are pushing around 1500 psi down the lines as opposed to 1000 psi for the standard units. Also check your lines to make sure that they can take the increased pressure. You do not want to blow a line out at sea, then you are really in it. You might want to call Teleflex and ask them about the cylinder and hydraulic lines required to match your new helm. Normally, replacing the cylinder is easy, You did all that nice work on your rig, so I am sure you can handle the cylinder install, just take your time bleeding the system and don't force anything. One person can bleed the system real quick. Again, it might be a good idea to check with Teleflex on the CYLINDER and HYDRAULIC LINES needed for that new helm to see if your existing lines are ok. If you rebuild the existing cylinder, you might have the same problem happen again because of the increased pressure coming from the helm. |
alkar
posted 07-08-2003 09:18 PM ET (US)
Thanks guys.Geeze. It didn't even occur to me that there might be a compatability problem as a result of higher operating pressures. I just assumed that the steering would be slightly more difficult as a result of a lower mechanical advantage, but I know next to nothing about hydraulics. The existing cylinder is mounted outboard of the starboard engine. The cylinder is in line with the "tilt axis" of the motor. It is "converted" into a dual engine system only by a tie bar assembly that connects the two engines - but the hydraulic cylinder communicates directly only with the starboard motor. The cylinder has a Teleflex part number on it (HC5370-71) and says "Outboard Hydraullic Steering". My next stop is the Teleflex web site to try to match the numbers. |
alkar
posted 07-08-2003 09:34 PM ET (US)
It looks like the 5370 cylinder is still available. According to the Teleflex web site, it goes from lock to lock in either 5.7 or 4.8 turns, depending, I assume, on the pump. |
diamondjj
posted 07-08-2003 09:54 PM ET (US)
Alex, That new helm that you installed, is it a Seastar Pro model ? That part number of your cylinder is a side mount cylinder which is not recommended for use with the Seastar Pro model helm. |
posted 07-08-2003 10:10 PM ET (US)
Working on the boat for the first time since October, I discovered last weekend that my hydraulic helm pump was low on fluid, too. I could not see a leak at the transom or at the rear of the helm pump, but I suspect that fluid leaked from the helm pump and was retained in the metal "box" that wraps around the pump and is used to mount it to the console.The Teleflex literature gives good information on how to bleed the system properly. It also gives good diagnostic information, too, on how to observer changes in fluid levels in the pump as indicators of air in the line. I highly recommend wearing disposable latex gloves when working with hydraulic systems and bleeding them. The hydraulic oil likes to escape from the system about as easily as gamma rays come out of plutonium--that stuff gets all over your hands in a hurry. I got the system refilled sufficiently that I am ready for sea, but I probably will give it another bleed and refill cycle after I dig into the helm pump more closely to see if it has been leaking.
alkar
posted 07-08-2003 10:34 PM ET (US)
diamondjj,If memory serves, I originally had a 1.7 cubic inch pump and I upgraded to the 2.0 cubic inch displacement model. Is the "pro" the 2.4 inch model? I'm not sure. I remember digging in this area extensively, and I was confident about my decisions at the time I made them, but I've done an awful lot of purchasing and building since I bought that pump. I'm not confident that my memory is correct - but I'm pretty sure I didn't buy the pro model. I'll check when I get back to my paperwork. (The paperwork is in my buddy's barn about ten miles from here.) I can't see any external evidence of a leak in my system, and the hoses appear to be in great shape, so I leaning towards rebuilding or replacing the cylinder. The rebuild kits are available - but then I still wouldn't have the new bleeder valve nipples... I'll probably just bend over and buy the upgrade. That's what I've done the last twenty times I've been presented with a similar choice. Hopefully I'll run out of upgrades before I run completely out of dough... Thanks for all the wonderful advice. You guys are great! Alex |
acseatsri
posted 07-09-2003 12:37 AM ET (US)
Save your money. If it's skipping and slipping, I highly doubt it would be the cylinder. There are only 3 working seal areas if it's a center mount- each end cap where the piston rod exits the cylinder, and the seal inside the piston itself that separates the left and right halves. You'd see the leak from either end of the cylinder, and if the piston seal was leaking, you'd just be getting "blowby" and the steering would be a little slower without the accompanying skipping and slipping. Find your leak. It's air getting into the system- it can only be introduced if it is displacing oil. |
diamondjj
posted 07-09-2003 09:38 AM ET (US)
Alex, Before you purchase anything, locate your paperwork on the new helm pump for the part number so we know which one you have. The pro models are also available in 2.0 as well. You will need to start there now that you already have the helm pump and make sure that either your existing cylinder or any new cylinder you may get, matches your helm. On another note, do not throw away your old helm pump, they are rebuildable. I think the rebuild kits are not more than $30.00 and it is not that difficult to do.acseatsri Alex, is not seeing any external fluid leak. We are all assuming that he is not adding fluid to the system (Alex,is that true). The only questionable area is that one bleeder screw that he cannot fully tighten, but I would think that when turning the helm, he would see fluid leaking out around the bleeder screw as the system pressurizes. The only other questionable area would have been the helm pump, but he replaced that with a new one. That only leaves the hydraulic lines which he stated are ok or the cylinder which is the only remaining original component that is suspect. If air is getting into his system, I would think that he would be seeing fluid leaking on the outside. The only other item could be that re-bleeding of the system may be necessary as suggested by several posters. |
diamondjj
posted 07-09-2003 09:51 AM ET (US)
jimh, Does that metal box enclose the steering shaft where it enters the helm pump ? You might want to check that area for any visible signs of fluid which would indicate that the steering shaft seal needs replacing. |
alkar
posted 07-09-2003 12:31 PM ET (US)
I have not added any fluid to the system since the original installation.I can not see any evidence of a leak, but I can not guarantee that the system has not leaked. That is, the allen heads are in an area that is regularly bathed by water when the boat is being used, so it's possible that very small amounts of fluid have escaped while I was running the boat and the evidence of the leak washed away. The hoses at the helm are dry and shiny. I can not speak to the condition of the hoses running through the tunnel, as I have not removed them. Can one of you guys explain how the quality of the steering could degrade over 20 or 30 days if the system were NOT leaking? I mean, if my bleeding job was ineffective, wouldn't the steering be sloppy right from the beginning? |
diamondjj
posted 07-09-2003 01:56 PM ET (US)
Alex, Sent you an e-mail at whaler22. |
acseatsri
posted 07-09-2003 02:35 PM ET (US)
"Can one of you guys explain how the quality of the steering could degrade over 20 or 30 days if the system were NOT leaking? I mean, if my bleeding job was ineffective, wouldn't the steering be sloppy right from the beginning?"Exactly! It HAS to be leaking, and my money is on the bleeder screw that won't tighten up. It would have to be a slow leak and only under pressure. You haven't mentioned if you've checked the fluid level in the reservoir. It doesn't have to be down much for air to be pumped into the system. Try refilling the reservoir, then turn the wheel HARD so that you pressurize the side with the stripped bleeder screw- It has a pressure relief valve in the helm pump, so don't worry about pushing it too hard. That should pressurize it enough to make the leak appear noticable. It'll probably feel spongy with all the air in the system. Put a piece of paper under the bleeder screw to catch any oil drops.
acseatsri
posted 07-09-2003 02:56 PM ET (US)
One other note- I'd fix the screw whether it's leaking or not (I believe with 90% certainty that it is!). Since you have to bleed the system anyway, I'd remove the cylinder and then proceed to drill it out to the next size up and retap it while holding it upside down (upside down will allow minimal intrusion of metal filings into the system)- I believe they're 8-32 socket head cap screws now, so you could go to 10-32- you may be able to just retap the hole without drilling it out- the outside diameter of an 8-32 screw is the same size as the root diameter of a 10-32 screw. Be careful doing this- don't force the tap and break it off! Use a short tap handle. |
tomroe
posted 07-09-2003 03:55 PM ET (US)
If you are going to tap for a 10-32 screw, you should drill with a number 21 bit. If you are drilling and tapping stainless, go slowly and reverse the tap often to clear the chips. |
lhg
posted 07-09-2003 05:03 PM ET (US)
Alex, you already have the Side Mount cylinder, which is what I recommend and use myself, on both Whalers. I assume you have checked out JimH's reference article on this subject. If the engines are CR, the cylinder should be moved into the port engine tilt tube. If the engines are not CR, the tilt tube in the starboard engine should be reversed, and the cylinder installed from the other side (between the engines). This will GREATLY assist in countering dual prop steering torque.I believe the proper helm for the single side mount cylinder is the Sea Star I, with the 1.7 capacity. The Sea Star HP (Pro) is the 2.0 capacity, and I believe is only compatible with the front mount cylinder and not for twin engine use. The Sea Star II is the 2.4 capacity pump, for twin cylinder installations on twin engines, either side or front mount cylinders. So, yes, you may have a compatibility problem. That helm may be overpressurizing the cylinder. I would call Teleflex in Vancouver. The reason BW furnished the side mount cylinders on the WD boats was for tilt-up clearance. However, if the engines are mounted all the way up on the WD, as they should be, you may still have enough tilt-up clearance using the new front mount cylinder. New tie bar design will be required. Your other option would be to sell off the "Pro" series pump, (should be a good market for this unit) and get a Sea Star I, or as mentioned, re-build your old Sea Star I. If it were me, I would stay with the side mount system, installed as I described above and elsewhere on this site, even if you need a new cylinder. |
alkar
posted 07-09-2003 05:33 PM ET (US)
I ran over to my buddy's barn during lunch and pulled out my receipts. The new pump I bought is a 2.4 cubic inch pump, but it's not a pro series. I dug a little further and found copies of my original correspondence with Al Campbell from Teleflex. He's the fellow who directed me to purchase the higher volume pump in the first place. He said that, assuming I had the HC5347 cylinder, the new pump would yield lock to lock in only 3.4 turns with a negligible increase in turning effort (maybe 5%).I originally e-mailed Al last February because I needed his help identifying the pump I had, and I needed some advice on how to improve my performance. At that point I was primarily interested in reducing the number of turns it took to move from hard right to hard left. Al diagnosed my original pump from my description. (You're right Larry. It is a 1.7) Al directed me to the 2.4 pump and I bought it. There are no compatibility problems as the operating pressures of the three pumps we spoke of are either the same or nearly the same. In fact, my receipt from Go2 Marine actually shows the relief valve pressure settings for the 1.7, 2.0, and 2.4 systems. They are all set at 1000 psi. I just e-mailed Al with this updated dilemma and asked for his thoughts. I'm hoping to hear from him soon. I'll share whatever Al tells me with you guys. I hate to be screwing with this kind of stuff in the middle of prime boating season! |
alkar
posted 07-09-2003 05:37 PM ET (US)
p.s. Al Campbell knew I had a 22' Whaler with twin Honda 115s and a HC5370-71 cylinder when he recommended the 2.4 pump, so I don't think there is a problem with compatibility. |
acseatsri
posted 07-09-2003 08:49 PM ET (US)
I just looked at my cylinder- it looks like 1t's either a 10-32 or a 1/4-28 thread, so you may have to go larger yet- if it's a 10-32, you can go up to a 1/4-28 - the drill size I believe would be .213- if it's a 1/4-28, you'll probably be best served by going for a 1/16 pipe tap- I might go this route anyway since it will be self-sealing and you could probably get a bleeder fitting in this size. You might be best served to take it to a machine shop and pay a little more for the job done right the first time. |
alkar
posted 07-10-2003 02:39 PM ET (US)
I got the scoop from Mark at Teleflex. (Al has yet to respond.)The symptoms I described are not consistent with a bad cylinder, which is usually marked by hydraulic fluid leaking AT the cylinder. If I can't see a leak, it's probably Okay. Mark explained that the 5370-71 is an unbalanced system so, if the system was incompletely purged, it would be possible for air to "hide" in the cylinder and gradually migrate back to the pump where it would increasingly degrade the power steering. To test for air in the system Mark instructed me to do the following: "Walk back to the motors and see if you can manually push the motors from side to side. Any movement, even a quarter inch, suggests that there is air in the system." Unfortunately, my motors weigh 505 pounds each, so they are not prone to move, but I'm going to try the test and re-bleed again anyway. The nipples can be retrofitted, so I'm probably going to order a set... I hope this works. |
alkar
posted 07-12-2003 11:32 AM ET (US)
We finally got it figured out! There WAS a leak, and it WAS at the stripping bleeder screw, but it only leaked under the high pressures generated by a hard left turn. The leak was extremely difficult to find, because it only shows up at the extreme end of the turning range. Even then the leak isn't visible from the helm, and it leaves no evidence behind, as it is a tiny pin-like spray that vents aft. As soon as the steering pressure is released, it stops spraying, and there's no sign that it leaked! I found the leak by having my son turn the wheel as I stared at the fitting - and I still would have missed it if I hadn't been right on top of it. The spray was so fine it turned into a mist a few inches from the fitting. (Which also explains why it took two weekends of use for the steering to degrade to it's present condition.) I'm ordering two new "Horizontal Bleeder Tees" today. Thanks for all your help guys. |
acseatsri
posted 07-12-2003 02:47 PM ET (US)
Exactly as I said! Glad you found it. :) But I also think you'll have a problem if you don't retap it, unless the bleeder tees are a different size which need to be drilled and tapped out to a larger size anyway- they're really unnecessary. I'd really suggest you take it to a machine shop to have this done, perhaps with a 1/16 pipe tap and plug. The other suggestion I'd make is that you buy the filler kit that teleflex offers- it's about 12 bucks, screws on top of the oil bottle and threads directly into the fill hole, and will make bleeding much more effective and easy if you're able to keep the helm full while bleeding. A small price to pay considering you were almost ready to shell out for a new cylinder.
alkar
posted 07-12-2003 11:03 PM ET (US)
I went to the local Honda dealer/marina to buy a fill kit and one of the mechanics just gave me one. He had a dozen or more of the kits in the bottom of one of his tool boxes. He just shrugged and said, "I get one with every system we install."The bleeder Tees should make bleeding my system much easier in the future, as you can shut down the bleeding while the bleeder screw in still surrounded in oil, thereby minimizing the opportunity for air intrusion. Since the Tees screw directly into the cylinder, and the new bleeder screw assembly is part of the new Tees, I will not have to do any tapping. The convenience and upgrade are worth the $37. I'm a firm believer in upgrading or replacing whenever it's a close call. It saves frustration, time, money, and anxiety in the long run. |
acseatsri
posted 07-12-2003 11:56 PM ET (US)
"Since the Tees screw directly into the cylinder, and the new bleeder screw assembly is part of the new Tees, I will not have to do any tapping. The convenience and upgrade are worth the $37."Yes, they screw directly into the cylinder, probably into the same stripped holes the bleeder screws are in now. :) |
alkar
posted 07-13-2003 09:43 AM ET (US)
Nope. The existing bleeder screws actually screw into a small fitting. The fitting screws into the cylinder. The new bleeder Tees replace the old fittings, so I should be good to go. (That misunderstanding was my fault, as I incorrectly referred to "tapping the cylinder" instead of "tapping the cylinder fitting". Sorry for any confusion.) |
acseatsri
posted 07-13-2003 10:15 PM ET (US)
At any rate, the stripped bleeder screw will continue to leak. You still need to plug it. The one thing I can say is that after switching from cable to hydraulic steering, it would be tough to go back to the cables. |
kingfish
posted 07-14-2003 08:19 AM ET (US)
I read Alex to say that the stripped threads were not in the cylinder, but in a fitting that is tapped (with good threads) into the cylinder. So when the old fitting goes, so goes the stripped threads. The new fittings thread directly into the good threads in the cylinder, and thus no leak. |
alkar
posted 07-14-2003 11:26 AM ET (US)
Roger that Kingfish. That's what I meant to say. Thanks for your help.:) |
posted 07-14-2003 11:42 PM ET (US)
I was interested to read about the possibility of the air migrating toward the helm pump. This seemed to happen in my system over the winter, although I find it hard to account for THAT much air being in my lines. The boat worked fine all last season, yet over the winter about a pint of fluid seems to have vanished. |
alkar
posted 07-15-2003 10:59 AM ET (US)
Jim, when you say that your system was working fine at the end of last season, do you mean that there was no slippage in the steering at all? The system does have a reservoir at the helm pump, so it will tolerate some loss of hydraulic fluid before the steering degrades noticeably. Since my system lost fluid at a cylinder fitting only when it was under higher pressure, the fluid level at the helm dropped very slowly. The steering degraded gradually at first, but it got worse very quickly on our last trip in to port - presumably because, near the end, the oil in the reservoir had been exhausted and each turn of the wheel was introducing MUCH more air. Maybe your helm was low at the end of the season, but it had yet to get to the critical stage. Of course, you could have a pesky leak like mine. The only way to know is to have somebody turn the wheel through the extremes while you watch the critical fittings.
lhg
posted 07-15-2003 05:18 PM ET (US)
That is why they tell you to pressurise the lines and system by turing the wheel over hard until the pressure relief activates. It will cause a leak to show up. |
alkar
posted 07-17-2003 03:54 PM ET (US)
I received and installed my Bleeder Tee's last night. What a difference! The installation and bleeding only took me about 20 minutes. Now the steering is as smooth as glass. Lock to lock now requires about 3.6 turns in one direction and 4.25 in the other. (That's the next thing to figure out. Work keeps getting in the way of my boat repairs.) When I bought my Tees, the marine supplier thought that they were individually packed. As it turns out, they're sold in pairs, so I have a extra pair to return. The pair cost $37 and change. If anybody here needs a pair I'll send them on, otherwise they're going back to the distributor in Florida. |
lhg
posted 07-17-2003 04:21 PM ET (US)
Alex - With the side mount cylinder, there is nothing else to figure out. It is an unbalanced design (unless two are used) so your turns are correct. That is why it can be used to counter propeller torque. The direction that has the larger number of turns has more "power", so that is why it should be reversed in the tilt tube to counter steering "pull". See JimH's reference article on my installation. |
frostbite
posted 07-17-2003 04:25 PM ET (US)
Lock to lock turns mysteryIn a dual acting hydraulic ram, the volume of fluid on opposite sides of the piston is different due to the displacement of the piston rod, less fluid pumping in one direction to get an equal amount of travel.
alkar
posted 07-17-2003 09:43 PM ET (US)
Thanks guys.Larry, I've ingested a great deal of information in the last 10 months, but I'm afraid much of it has slipped through the cracks in my brain. You're right, the information is right there in front of me in the reference section, no doubt absorbed and lost at least twice in the last ten months. I'm hoping it will stick this time. The reference section is a wonderful asset. |
