posted 07-14-2003 11:25 AM ET (US)
Austin,The parts in question are called stanchion supports. They are (on Whalers of your vintage) made of chrome plated bronze. You can buy new replacements from any Whaler dealer or directly from CMI Marine in Hingham, MA (781-740-1260). I believe these will be polished stainless steel and ever so slightly different in the shape of their casting.
Used stanchion supports are often available at used marine equipment shops or on Ebay. But understand that these are not generic off-the-shelf parts, but rather were (are) custom made for Whaler. There are also several different sizes/shapes so be sure you know what you want before you go shopping.
Bronze fittings can always be replated but not welded back together.
I might have a used stanchion support if that would suffice for you. Send me an email if you’re interested and give me the particulars and a digital photo if possible.
Generally speaking, the bow rail on the 16' 7" hulls have the stanchion supports on the middle stanchion attached with machine screws threaded into a cast backing plate on the exterior of the hull. The stern most stanchion supports screw directly into plywood backing in the hull. You can always retrofit the exterior backing plate if the wood or screw hole is too damaged to accept a fastener.
