posted 07-24-2003 05:12 PM ET (US)
Just finished installing a heavy duty black commercial monster rub rail on my 15 - very easy job (Kit # 500-05017 at around $158 plus shipping from Sue at Twin City Marine).It took me about 25 minutes to install complete using self tapping screws... needed my wife for two holds - did it in full sun after the rail baked for a couple of hours...
The jobs looks very professional and clean - the boat looks better and actually looks bigger / meaner... hopefully will scare away some whimpy electric boats. The end caps look awesome... very very clean look.
The only negative - I switched out using the BW sealer (one week to cure) with 3M-5200 so I could wash the boat immediately. I actually sealed all old holes and sft spots (after grinding away some areas) with Marine Tex and then screwed into the old holes for the best hold - with Marine Tex the old holes are now the thickess part of the hull along the rail... I put extra effort into remming out the old holes to make lots of room for a good bond. Plus the heavy duty rail is slightly bigger than the original rail and it completely covers my sloppy fill job.
Thanks Big Shot - without your earlier post/ comment on installing an original style rail (5 hour installation with three guys) I likely would not have returned the original style rub rail and would be still working on the stupid thing... and likely divorced.
Whoever offered the advice to work over grass - thank you. The rail would be marked up working on a hard surface like my garage.
cheers
Ian
