posted 08-09-2003 10:56 AM ET (US)
A little more description of the blisters would help me pinpoint it. Where are they? What is the size and shape of the affected area?Above the waterline, blisters are caused by improper curing of the resin, or improper wetting of the fiberglass during layup.
Resin blisters are repaired like osmotic blisters. Pop them, dig out the gooey part, fill with epoxy filler, and refinish. If the blisters are caused by uncured resin, more may appear after you do the repair. Resin blisters will usually cover a larger area than air blisters and may appear in a wavey pattern because of the way it is sprayed into the mold.
Air blisters are repaired the same way, but you can use gelcoat paste to fill the voids. Once you rapair an air blister it should be permanent. Air blisters usually occur in chines, strakes, or in a radius, where overwetting can cause the fibers to be squeezed out, making the skin to thin.
