posted 08-12-2003 08:20 PM ET (US)
Are you operating the trim from the helm control remote or are you operating the trim from the cowling-mounted control?Try both. This will help you isolate the problem. If one switch works and the other does not, you can infer an electrical problem.
A bad switch is common.
The electrical system also uses solenoids to operate the actual electrical motors that connect to the electrical pumps in the submerged trim unit. These can also be a source of problem.
Your owner's manual will also include a full wiring diagram that will help you trace the connections.
Many little in-line socket-plug connectors on individual wires are used by Yamaha in their electrical wiring. These can come loose, too.
I believe the owner's manual has a procedure for filling the trim system hydraulic fluid. Read through your owner's manual and you will learn a great deal about your engine from the people who designed and built it. The information content in most of them is quite high.
If you have a hydraulic problem, you may be low of fluid, have some stuck check valves, or have more serious problems.
With a decent understanding of electrical circuitry, some mechanical knowledge, and the owner's manual, you will be able to make a better diagnosis.
The reason I am familiar with this situation is I own two Yamaha motors and have experienced all these problems, including having to pay dearly for replacement parts via their dealers.
I recently spend several hours taking apart the cowling switch and repairing it--down to the internal contacts, etc. I probably saved myself $150 or more in part cost, just be cleaning out some corrosion caused by water leaking it.
