posted 08-27-2003 06:51 PM ET (US)
I've just checked out a 1987 Outrage 22 to possibly buy. Two main problems appear to be that the boat sat in the guys yard for atleast a year with quite a few leaves and water sitting in it. I didn't see it but was told, my impression is that the plugs were out so it wasn't a total bird bath but that the bildge area on the starbard side was always holding water as the drain sat with the trailer bunk blocking it.Question: does water sitting in this well ever create a problem of getting into the foam if there is no visible break in the gelcoat?
Second, and possibly more problematic, is the transom drain in the center under the engine has the outer 1/4 to 1/2 inch of brass tube missing. I couldn't get a great look (it was shaded by the engine). But what I did see was that the inner portion of the transom appeared white and to be "glassed" or coated with some veneer. It was not raw wood or exposed foam. Area around the thru hull appeared hard and did not flex at all.
Question: Is this most likely just a thru hull repair job or is it a case of probable water ingress into the transom itself?
Last, near the bow, on the inside where the deck forms that smooth curve up into the gunnels, I noticed a few 1/2 to 1 inch slits in the gel coat (not spider cracks or typical stress cracks). They don't look like anything external caused them but more like it just cracked from years in the sun.
Question: Is this anything other than a gel coat repair?
I love my Whalers and am always amazed to see some pretty rough looking neglected abused Whalers still motoring along. A testiment to their durability. I prefer to nurture my baby and keep it in tip top performance, but I wonder if sometimes I'm see the wear and tear that occurs and misinterprete it as structural hull failures when its nothing more than a TLC repair.
Thanks for your comments.
