arnereil
posted 09-01-2003 04:52 PM ET (US)
If you mean off, white, all..... the lights are always grounded... the first pull of the switch puts power to the white light, the second pull continues to feed the white and adds the red/green..... How do i know? On my new bought, used 13, the lights didn't work. checked fuse, fed separate power to the lights and they worked..... pulled switch apart and found corrosion. used a scotch brite pad to remove it and coated pieces with electricians anti-oxidation grease... put back together and works like factory fresh.. took some leg work, but was about the easiest fix it could have been.... |
