ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Securing Bow Door
Author | Topic: Securing Bow Door |
mrdrago |
posted 09-05-2003 08:16 AM ET (US)
My 1986 Montauk has a teak door on the bow compartment. In heavy seas it bounces because there is nothing securing it to the boat. Any suggestions or ideas for installing some type of fastner or hold down for it? As a follow-up, my door also has a hole where the previous owner had a pole to support a chair. Does anyone know of stainless hardware that could be installed to close the hole? Or something to make it look a little nicer? Thanks, Mark |
jameso |
posted 09-05-2003 08:36 AM ET (US)
Later model 15's used a bungee arangement to hold the anchor locker hatch in place. They also hinged the forward edge. The hole; go a local metal recycling yard and scrounge a small piece of stainless, file edges and polish if you want then attach with a couple of small stainless screws. my 02 to you. Jim |
ratherwhalering |
posted 09-05-2003 02:34 PM ET (US)
I toyed with this idea for quite some time, and came up with the following solution.
If I didn't have the pedestal mount, I would consider securing an appropriate length of bungee loop to the underside of the hatch, then mounting a retaining clip on the interior of the anchor locker wall, with just a reciever clip, like the one pictured here http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=30643 . You could use the finger hole to open the hatch enough to clip and unclip the bungee loop to the catch. I have not tested this, but it sounds like it would work. In addition, the hardware would be out of site, and not in the way of shins or ankles. |
Cicada |
posted 09-06-2003 11:11 AM ET (US)
Flush mount pull rings are available that need to be inletted into hatch. Depends on how big the hole is and availability of a size that would cover the hole. Bungee cord on the inside sounds good. I thought about using some kind of magnetic or cabinet latching mechanism but decided against it. Wanted to keep the interior smooth and just too lazy. Paul |
Cicada |
posted 09-06-2003 11:14 AM ET (US)
Also toyed with the idea of having something in a bikini sit on it continuously. Nixed that idea. Would probably lead to some rather vocal objections and would be in the way when fishing. |
bloller |
posted 09-06-2003 11:39 AM ET (US)
That's the best solution to that problem one could ever come up with. |
jstachowiak |
posted 09-06-2003 04:30 PM ET (US)
Lowes has heavy duty velcro, which seems to be holding down mine just fine. |
