ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Transponder, Late Mod Humminbird Loose. How Remove From Base Mount
Author | Topic: Transponder, Late Mod Humminbird Loose. How Remove From Base Mount |
Gene in NC |
posted 10-21-2003 09:50 PM ET (US)
I left base mount for Humminbird transponder a "litle loose" for final adjustment. Now it is tulouse as in LaTrec. Can't remember if the transponder electronic part can be snapped back off, or for that matter how it snapped on, except that it probably snapped down. |
cmarques |
posted 10-21-2003 10:55 PM ET (US)
If it is the same type transducer as my old 200dx humminbird it can be snapped back up-It is made to pop free on impact and the center electronic part pivots upward like a hinge. You may be able to pull a little to snap loose or pry gently from underneath with flat screwdriver. |
triblet |
posted 10-22-2003 12:15 AM ET (US)
Sounds like you just need to do the last bit of the install. http://www.humminbird.com/hb_Products.asp?id=27
Gene in NC |
posted 10-22-2003 12:28 AM ET (US)
Thanks, Chuck. You come through again. The manual is off at the coast, I hope, and I'm trying to get everything tunes up for a fishing trip this weekend. Good service from Humminbird, and I recognize the manual. |
