  Trim/Tilt "Clicking Noise"???
Author Topic:   Trim/Tilt "Clicking Noise"???
Outrage18 posted 10-27-2003 02:23 PM ET (US)   Profile for Outrage18   Send Email to Outrage18
Hello-
I have a 1995 150 Mecury Black Max, that clicks when going both up and down in the same spot. What could cause this noise?(Is it the relay?) And How hard is it to replace the gaskets to repait the old leaky trim problem?(It falls down after being tilted up for the night)
Right now I just flip up the mechanical lever that holds the engine up....
Any advice??
Thanks!!!
-Paul
Bigshot posted 10-27-2003 02:44 PM ET (US)     Profile for Bigshot  Send Email to Bigshot
Clicking is usually the pivot point hwere the tilt ram meets the engine's midsection, not in the pump. The leaking down is either an external seal leak whuch would require adding fluid and may be a cause of the clicking. Or an internal check valve that does not leak oil and requires a trim assembly overhaul to replace a $1 part. If the latter I would continue to use the tilt bar overnight until it gets worse.
Outrage18 posted 10-28-2003 02:52 PM ET (US)     Profile for Outrage18  Send Email to Outrage18
Thanks BigShot!
Anyone else want to share their knowlege of Trim/Tilt repairs?
Thanks in Advance
_paul
Swellmonster posted 10-30-2003 07:58 AM ET (US)     Profile for Swellmonster  Send Email to Swellmonster
My merc has the two rolling balls on the ends of the rods that contact the motor. They get sticky and sandy and slow and go clicky. I regrease them then they are happy for a while.
