Topic: Radar
NausetBoy |
posted 12-16-2003 01:41 PM ET (US)
Sorry for the NON Whaler question guys. I can get a good deal on a SI TEX Radar Dome and Display. What I propose to do is mount it on my roof of my dock. Then I can see weather, and other boats etc. Just for the heck of it. Problem is I have never used radar before. What all could I really see? I really want to do this. Thanks!Sonny
jimp
posted 12-16-2003 02:44 PM ET (US)
NausetBoy - Well, if your radar is tuned & operating correctly, you should see a lot. If you're looking at Mobile Bay you should be able to see ships in the ship channel (blips). Buoys marking the channel (smaller blips that don't move). Assorted other boats (assorted sized blips that move). Rain (hazy blob or mass). Severe weather (a hazy line marching across the screen). If there are any sandbars handy, they may show up also. Wooden/fiberglass boats should give some return, but not as much as a large ship. Somethings you'll see with your eyes - and they won't show up on radar (too small, no return, or an F-117 stealth fighter/bomber or B-2 - just kidding).You can use the range rings to see how far things are from your dock. Could be fun for a few days, or at parties - show your guests! If you set it up properly, or have somebody do it for you, radar is fairly easy to use and usually works by turning the switch to "On", or "Standby" then "On". JimP |
BugsyG
posted 12-16-2003 10:16 PM ET (US)
Hi Nauset Boy,I don't have radar on my whaler, however our biggest boat has radar. The important thing with radar is very crucial: Mount it way above your head. Because I see these boats that have radars really close to them. Radars give off radiation that is very harmful to yourself (particularly to your heart). So mount it high. Our boat is equiped with a Radar Arch, smaller boats too, but it is important to mount it on an arch if you are going to put it on the boat. P.S. How old are you? JAZZ |
NausetBoy
posted 12-17-2003 07:47 AM ET (US)
Thanks Bugsy and jimp.Bugsy- I am 17 and it will be mounted on the roof way above my head. Sonny |
Knot at Work
posted 12-17-2003 08:50 AM ET (US)
Donate a few from your swim team.... RF energy can be bad mkay... |
BugsyG
posted 12-17-2003 03:04 PM ET (US)
Hi Sonny,Yeah, I'm 16, I have montauk...email me at JAZZ17BW@aol.com :) I'll send you some pics! JAZZ |
andygere
posted 12-19-2003 12:49 PM ET (US)
Why not install the radar unit on your boat? Chances are you're not going to run aground or strike another vessel while sitting on your dock. |
NausetBoy
posted 12-19-2003 03:23 PM ET (US)
I do not have a boat with the capacity to hold radar. I would need an arch and other accesories. I am installing this unit for the hell of it. I got it for a good deal and why not? I can see squalls, ships etc. Sonny |
andygere
posted 12-19-2003 04:46 PM ET (US)
Actually, you don't need an arch or T-top to mount radar, you could put it on a mast that would work fine on your Nauset. I have radar on my Outrage, and it has really been valuable on many occaisons when the fog has rolled in. It is also very handy after dark for the same reasons. GPS will always get you back to the harbor, but radar lets you know where everyone else is, so you can be sure to avoid them. Big sailboats in a thick fog are quite scary because they can move almost silently and appear seemingly out of nowhere. It is also very handy after dark for the same reasons.If it was mounted on your boat, and your boat was at your dock, you could still use it to check out the weather, etc. |
NausetBoy
posted 12-19-2003 05:33 PM ET (US)
I would rather not mess up the good looks of my nauset with a 2 foot radar dome. Also, I do not do much night cruising and there is barley any fog here in Alabama. I would but it would not get used. Also my boat is either moving or in my lift so it would be useless in there. Also there are clearance reasons in my boat lift and garage and it would have to be mounted very high up to clear me. Also it has a 10" screen and there is not that much room on my console as there is already a GPS and fishfinder. I just want something to toy with to see boats, weather etc. One day when I get a bigger boat, ill know just how to read it.Sonny |
Knot at Work
posted 12-19-2003 06:08 PM ET (US)
Some RADAR theory for you... the RADAR Horizon is the approx Formula to compute distance seen by a RADAR based on Target (Ships or land in this case) and the Antenna.A rule of thumb is 1.23 times the square root of the Antenna Height so for example: A 6 foot antenna should be able to see a contact at 3.01 miles. This is a limiting factor of RF Propagation without regard to a environmental factor like surface ducting or scattering. it is also called RADAR Line of Sight (LOS) Range is a factor all to itself... PRF or Pulse Repetition Frequency is the Output of RADAR source. Usually measured in MHZ. The RANGE of RADAR is dependant on the Signal going out and coming back. So two way travel is a measured in YDS and is approx 81,000 yds for one way travel and 162,000 yds back to the receiver. The Ability to see two contacts on the same bearing is a factor Pulse Width. This a factor of Antenna Shape |
dfmcintyre
posted 12-19-2003 08:35 PM ET (US)
Knot - Regarding the formula; wouldn't the effective range change, depending on the height of the object that the pulse is reflecting off of? In other words, you might spot a 6 foot high boat 3.01 (using your excellent example) away from you, but a 100' structure would be observed much farther away. Don |
Knot at Work
posted 12-19-2003 11:21 PM ET (US)
Don, you are correct Sir,Actually I only gave half the formula as I am used to it as application for Airborne Search Radars the correct exact formula is 1.23 x Sqrt of Antenna Alt times 1.23 x Sqrt of the contact.... thanks
whalerron
posted 12-20-2003 12:27 AM ET (US)
I'm gonna go out on a limb here. Does anybody have a saw?Isn't your equation ignoring a few things. Effective range of the radar is also dependent upon: Antenna gain Cross Section of the target Average power of the transmitter Wavelength of the transmitted signal Antenna scan rate In a vacuum, the maximum detection range of a radar system = 4th root of (P*G*c*A*t)/((4pi**2) * Smin) where P=average transmitted power G=antenna gain c=radar crosssection of target A=effective area of antenna t=time-on-target. Also could be pulsewidth if P is the Peak power instead of the average power. Smin=minimum detectable signal of radar. This is based on the system's signal-to-noise ratio Pulsewidth is the duration of a radar's transmitted pulse. It's the distance between the leading and trailing edges of the pulse as it travels through space and it's a function of the transmitter. Notice that the detection range increases at a rate of 1/4 the amount that transmit power is increased. So, a 2000W system is NOT going to have double the range of a 1000W system. Outside of a vacuum, in the real world, the range is decreased by the atmosphere, the target not being centered in the transmitted beam and by the fact that the some of the reflected returns are not from the center of the transmitted beam. The "target not being centered in the transmitted beam" can be an issue if the radar antenna is mounted too high. The bottom portion of the transmitted beam might be causing target returns and those returns will be weaker than if the main part of the beam had hit the target. Antenna shape does play a part in antenna gain and in the transmitted beam shape. |
posted 12-20-2003 12:37 AM ET (US)
PORGIE: Can that radio get Duluth?RALPH SPOILSPORT: Duluth? That baby can get Tierra Del Fuego! |
HAPPYJIM
posted 12-20-2003 07:45 AM ET (US)
Sounds like a Tweet Convention to me! |
Knot at Work
posted 12-20-2003 08:29 AM ET (US)
WhalerRon-The Funcionality of RADAR is actually dependant on the PRF or Pulse Repetition Frequency. Certain Radar Frequencies travel farther. example an I-Band Radar (a typical Search RADAR) should always be limited by the Radar LOS. RADAR LOS is the THEORETICAL RANGE of that radar based on antenna height and Contact. Radar Cross section had little to do with range. Either a contact will reflect RF energy Back or it will not.
Pulse Width is a function of a RADAR beam going out and decerning two contacts on a same line of bearing at different ranges. Range Resolution is to determine two contacts on same range at different bearings. There are volumes written on Radar Theory, my lessons taught to me in the Navy are for Aviation Anti-Submarine Search Radars, primarily the LN-66 Made by Marconi. Great Radar! |
whalerron
posted 12-20-2003 11:39 PM ET (US)
I wonder what the radar cross-section of a 16'7" Whaler is? I often wonder whether my boat even shows up on radars. There is anything there to generate a return other than the outboard's powerhead. |
Knot at Work
posted 12-21-2003 08:19 AM ET (US)
Depends on the Radar. SPY-1 Radar on Aegis Class Cruisers can pick up bolts left over from Sky lab in orbit.On the Aircraft Carrier I served on in the Arabian Gulf, our Radar in Operations could not usually pick up the Iranian Boghammers or Whalers. (yes the Iranian Islamic Republican Guard uses Whalers) BUT the Commanding Officer had a Faruno on the bridge, and they could pick them up. Not so much the boat itself but the Wake caused by the fast movers and the Sea Return showing up on a wake. |
alkar
posted 12-21-2003 11:01 PM ET (US)
Hey Knot, I'm shopping for a small radar unit and I'd like some advice. (I'd like to pick it up this week.)My radar arch will place my antennae about 7' above the water. Given that limitation, is there any reason to look for radar designed to be effective at 24 miles? JRC makes a 1000 series and a 1500 series. The main difference between the two units is the peak signal strength, but both are supposed to be more than adequate at ranges of 8-10 miles. (Actually, the theoretical range is 16 miles, but the less powerful unit probably isn't "seeing" much at that range.) It sounds like my low antennae height will limit me to more like 6-8 miles regardless of which unit I buy (assuming I'm trying to pick our small craft.) What do you think? Alex |
Knot at Work
posted 12-22-2003 09:14 AM ET (US)
Alex, your question requires two answers. first of all assuming that your Antenna Heigth is 7th feet your Radar Horizon or Line of sight is only 3.25 Miles. This is a factor of physical location of antenna. Not neccessarily what you really see regarding ranges. Assuming your Radar Antenna is a rotating antenna and if it has a slow RPM setting, I think 12 miles is a reasonable range to expect from your radar set. 12 Miles is also the rule of thumb for visual horizon and curviture of the earth at mean sea level. A few factors I have not really touched on are the environmentals that effect Radar signals. There is always ducting that occurs near surface. This is a factor of Moisture and particles suspended in the air or whatever transmission medium you use. It is not uncommon to see extended ranges at the surface on a radar display out to 48 and even 150 miles... this is based on ducting that produces a sound channel for the radar wave to bounce off... A example is AM radio stations on a cloudy night... some times you can receive AM signals hundreds and thousands of miles away due to the surface ducting. Short answer... yes your surface radar ranges should be reasonable to ranges of 8-24 miles. Keep in mind Operator proficiency is also critical and you will need to practice with a sea return, high and low RPM's (will change your PRF as they rquire a different and varying frequency at different RPM) and background noise (like clouds, rain, shoreline, jetties and the like) Hope this helps. Jeff |
Plotman
posted 12-22-2003 10:15 AM ET (US)
Alkar - remember that your "radar horizon" based on your antenna height is the distance that you can theoretically pick up a target right at the surface of the water. Not the distance you can pick up a "normal" target, since any target above the water should also have a "horizon" (figured out the same way) that will tell you the distance an antenna at water level can "see" the top of the target.Your effective detection range will be the sum (plus, not times as indicated above) of these two distances. So, with a 7 foot high antenna (3.25 mile radar horizon), you should be able to pick up: * a 7 foot high target like another boat at 6.5 miles (3.25 + 3.25). * a 50 foot high target (lighthouse, small ship, etc.) at 11.9 miles (3.2 miles + 8.7 miles). David |
Knot at Work
posted 12-22-2003 10:21 AM ET (US)
Plotman,Thanks for correcting my bearing drift. I thought I put plus, infact I erred and put times you are correct 1.23 sqrt of Antenna PLUS (+) 1.23 sqrt of contact antenna = los or horizon |
alkar
posted 12-22-2003 10:46 AM ET (US)
Thanks guys. That was helpful.So...do you think there is any percentage in ponying up the extra money for the power necessary to improve the effective range? In other words, given the limitations you describe, wouldn't it be silly to install 24 or 48 mile radar when you can only get it 7' above the water? |
Plotman
posted 12-22-2003 12:00 PM ET (US)
A more powerful radar with a larger antenna will be better able to discern small targets at closer ranges than a less powerful unit.For example, a 24 mile radar will typically be able to pick up a smaller (less reflective) target at 10 miles than a 12 mile radar would, all other things (like the antenna & target heights, sea state, rail, etc.) Then again, you have to balance this against cost, power consumption and antenna size. I would think that in a small, maeuverable boat like a whaler, you are really mostly concerned with seeing things that are within a mile or two of your boat, assuming that you have a GPS that can tell you generally where you are and what direction you want to go. For example, GPS gets you close to the harbor entrance, radar allows you to steer between the piers once you get there. In terms of avoiding collisions with other boats or fixed objects, you really care most about what is within a few hundred yards. David |
Plotman
Plotman
posted 12-22-2003 12:01 PM ET (US)
Plotman
andygere
posted 12-22-2003 12:32 PM ET (US)
There is another good application for the use of radar on a small boat, and that's fishing. Often when the salmon are scarce, folks become reluctant to share GPS numbers for good fishing groudns on the radio, or they may give bad information. By setting the radar to the 16 mile range, I can see most of Monterey Bay and identify where the fleets of trollers are located. There is no way to tell if they are catching fish, but it often gives a good starting point. Bigger reflections from commerical boats are always a good sign. I imagine this is a good techinique for finding feeding albacore as well, although I haven't tried it yet. |
alkar
posted 12-22-2003 09:09 PM ET (US)
Thanks guys. I went with the more powerful unit. I was the the winning bidder on a JRC 1500 with an 18" dome. I can't wait to get it! |
WSTEFFENS
posted 01-06-2004 12:18 PM ET (US)
Gentlemen:I have read this string with great interest. I however have a question that some of you more knowledgeable users of radar might be able to answer. Considering the 3-4 mile horizion due to antenna height, would a smaller unit such as the JRC, have the power to punch thru dense fog or heavy rain at that range? Or is it still a matter of large dome (big antenna) 18" vs 12" and as the hot rodders say there is no substitute for power. Thanks WLS |
Tom2697
posted 01-06-2004 12:56 PM ET (US)
I don't know about heavy rain but my JRC 1000 works fantastically in fog! I have my antenna about 7 feet above the deck so about 8-9 feet above the water when running. Most marks that I pick up are within the 6 mile rings but I do pick up shrimp boats and oil rigs out to around 10-12 miles though. |
