posted 01-11-2004 11:44 AM ET (US)
Chad - I've place a single in two different Montauks and currently have a dual setup in an older Outrage....the one that has the smaller Montauk type console. If you mounted them so the long portion of the battery(box) is aligned bow/stern, you might be able to fit them.
One need to either cut openings in the console floor so the box will rest on the hull, or brace the floor from underneath. The standard console floor is not strong enough to hold even one battery.
By adding two risers under the console, the two boxes barely protrude into the console area. Actually just the battery box lids. The box it self is flush to the console floor.
Don
