  Real Reverse Engineering- '87 OMC Rectifier/Regulator Back to Straight Rectifier?
Author Topic:   Real Reverse Engineering- '87 OMC Rectifier/Regulator Back to Straight Rectifier?
Gene in NC posted 03-11-2004 05:57 AM ET (US)   Profile for Gene in NC   Send Email to Gene in NC
How tough to really reverse engineer charging system on '87 90 OMC from rectifier/regulator back to straight rectifier?
No time or resource to replace R/R. Why not convert to rectifier. Have the part. No need to pull flywheel. R/R not used for many many years before the '80s.
tuna1 posted 03-11-2004 10:11 AM ET (US)     Profile for tuna1  Send Email to tuna1
86-87 90hp had two different R/R that were used depending upon if it had trim/tilt.Best to fix so you have a more uniform voltage for your other onboard electronics.GO AFTER MARKET partsto reduce costs.
Gene in NC posted 03-11-2004 11:33 PM ET (US)     Profile for Gene in NC  Send Email to Gene in NC
Tuna 1, you must be right about regulator on '87 OMC, but if so how do we explain my '79 100 Evinrude with T@T but only a rctifier w/o a regulator?
tuna1 posted 03-12-2004 07:53 PM ET (US)     Profile for tuna1  Send Email to tuna1
Newer marine electronics need a more uniform voltage(those with microprocessors)
Gene in NC posted 03-13-2004 10:03 AM ET (US)     Profile for Gene in NC  Send Email to Gene in NC
Tuna 1, do newer electronics include my threee year old Humminbird fishfinder? If so, would what would be the effect of the unregulated '79 OMC
Gene in NC posted 03-16-2004 12:51 PM ET (US)     Profile for Gene in NC  Send Email to Gene in NC
Another alternative is to clean all the R/R wire connections in that little strip on stb side of engine. Suspect that's what got mine going.
