posted 03-01-2005 09:28 PM ET (US)
Go to the sunbrella web site.
Sunbrella recommends the following: copied from an i-boats thread. They recommend washing with woolite or ivory snow and cold water first, rinse and let dry in the air first.Re-treating the fabric
As part of the finishing process, Sunbrella fabrics are treated with a fluorocarbon finish, which enhances water repellency. This finish is designed to last for several years, but must be replenished after a thorough cleaning. Based on test results, Glen Raven recommends 303 High Tech Fabric Guardâ„¢ as the preferred re-treatment product for Sunbrella fabrics. Fabrics should be retreated after thorough cleaning or after five years of use. Check with your local Sunbrella dealer or distributor for more information.
Applying 303 High Tech Fabric Guardâ„¢
303 should be applied to Sunbrella fabrics after each thorough cleaning, which typically removes the original fluorocarbon finish and reduces the fabric's water resistance. After cleaning the fabric, allow it to air dry completely and then apply 303 in a thin, even coat. After allowing the first coat of 303 to air dry, apply a second thin, even coating of 303. Two light coatings are more effective in restoring fabric water resistance than a single heavy coating. The 15-ounce aerosol provides coverage of up to 50 square feet of lightweight fabric.
