macfam
posted 04-10-2005 09:04 PM ET (US)
George, Last year I had the same problem with my 2000 Johnson 40hp. Sad to say, it finally stopped....amd DO mean stopped!!! It stopped working....period. It happened Sunday before the 4th of July weekend. The local marina was great sna got it repaired by Friday morning before the 4th. A new pump w/labor for at total of $500!!! Everything worked fine until late in the season. Then I find that it goes UP fine, but on the way down it does this,"clunk, clunk , clunk" crap. I suspect the pivot points simply need new grease (I hope) I've got to get to it in the next few weeks to find out.One point to check out: Place your trailer tongue on the ground, and if possible, headed downhill before you top-off the fluid refill. That maximizes the amount of fluid possible. That seemed to speed up the up and down movement. Best of luck! |
