Topic: Fuel pump in '95 Rage 15
flfisher |
posted 07-16-2005 12:50 AM ET (US)
Does anyone know where the fuel pump is at in this boat? It has a 115 Omc in it. It will only run for 2 mins only after priming it. Thanks for any advice.
flfisher
posted 07-16-2005 09:49 AM ET (US)
Anyone?????? |
tuna1
posted 07-16-2005 06:57 PM ET (US)
The fuel pump is in the same stock location as on OMC V-4 outboard powerhead,on the starboard side. Follow the fuel hose to the powerhead.Same part as on OMC outboard.Check your fuel filters for restrictions.You could also have a problem with the antisiphion checkvalves at the fuel tank outlet,required because the outboard powerhead is concidered a inboard engine as used. |
