PFSQUAN
posted 01-26-2006 10:10 AM ET (US)
The technique is called feathering. If the repair section is the diameter of a dime, for instance, sand the surrounding area so it meets the damaged surface gradually. New varnish then can be used to fill the hollowed section for a seamless repair. Two additional coats over the entire surface should blend in everything like new. It is similar to any fiberglass repair, where you would grind off the adjacent area so the new glass or gelcoat bonds with a smooth transition, not an abrupt one. If possible use a sanding block so the existing varnish is scuffed up evenly over a larger area than the localized damage. If you just use your fingers, you are apt to leave depressions in the surface that may not fully reveal themselves until after you top coat. Good luck. Peter |
