  Yamaha 703 Remote Control Tachometer Wiring
Author Topic:   Yamaha 703 Remote Control Tachometer Wiring
Dave UK posted 04-30-2006 08:28 AM ET (US)   Profile for Dave UK   Send Email to Dave UK
I need to wire up a non-Yamaha tachometer. Exactly what are the functions of the four coloured wires? I'm technical so I should understand!
Thanks
Dave
ASIDE: Does anyone have the manual for a Yamaha 703 remote control?
jimh posted 04-30-2006 11:01 AM ET (US)     Profile for jimh  Send Email to jimh
The usual wiring to a tachometer will have:
--switched +12 that follows ignition switch on engine so has voltage in RUN and START positions;
--battery negative or common;
--tachometer pulses from engine;
--gauge illumination.
The wiring color codes are somewhat standard for this, at least with outboard engines manufactured in America. I don't know what the Yamaha color code might be. I will go use GOOGLE.COM now to search for this, as I think it will be a good addition to my REFERENCE article on color codes. See:
http://continuouswave.com/whaler/reference/wireColorCode.html
If Yahama follows the usual color codes that would be:
--switched +12 that follows ignition switch on engine so has voltage in RUN and START positions; VIOLET
--battery negative or common; BLACK
--tachometer pulses from engine; GRAY
--gauge illumination. BLUE
But that is just speculation. I'll be back if I find more accurate data.
jimh posted 04-30-2006 11:07 AM ET (US)     Profile for jimh  Send Email to jimh
I found some information, not absolutely authoritative, that Yamaha uses some different colors:
GREEN = Tachometer Sender
YELLOW = 12-volts from IGNITION KEY
jimh posted 04-30-2006 11:17 AM ET (US)     Profile for jimh  Send Email to jimh
I did some more searching and found this citation:
DARK GREEN = Tachometer Sender
YELLOW = 12-volts from Ignition Key
BLUE = gauge illumination (hey they got that right)
BLACK = battery negative
GRAY = overheat alarm
Again, this is not authoritative.
SIM posted 04-30-2006 12:14 PM ET (US)     Profile for SIM  Send Email to SIM
Jim,
You last post or the one above this is correct except there is no gray wire in the 703 power harness from the Yamaha 703 control.
Dave.......send me an email to parts@shipyardisland.com and I will reply to that and attach the 703 control installation book from Yamaha.
Andy
Dave UK posted 04-30-2006 12:17 PM ET (US)     Profile for Dave UK  Send Email to Dave UK
I should have said what the colours were, sorry. They are black, yellow, green and red. What do you think ? The engine is a 1998 25hp 4 stroke Yamaha on a friends very nice 13 Sport with lovely restored wood. My 15' SSL is going great with a 30hp injected Mercury.
Thanks
Dave
jimh posted 04-30-2006 12:52 PM ET (US)     Profile for jimh  Send Email to jimh
Andy--Send me a copy and I'll include the wiring code information in the REFERENCE section. I would much prefer to get it from an authoritative source like the factory manual.
SIM posted 04-30-2006 01:19 PM ET (US)     Profile for SIM  Send Email to SIM
Dave,
Follow Jims last thread. That info is correct. I also got your email and sent you the 703 info.
Jim,
Will do on your request.
Andy
Dave UK posted 04-30-2006 01:46 PM ET (US)     Profile for Dave UK  Send Email to Dave UK
Andy, you are a star ! I can't see the wiring diagram or colours though.
Thanks
Dave
Dave UK posted 04-30-2006 03:17 PM ET (US)     Profile for Dave UK  Send Email to Dave UK
Andy
Got it, a big thank you from the UK, where petrol ( gas ) is now $6.63 a US gallon !
Dave
15' SSL
