  Mercury 60-HP Four-stroke: Problems with Access to Spark Plug and Filter
Author Topic:   Mercury 60-HP Four-stroke: Problems with Access to Spark Plug and Filter
Speedo66 posted 11-09-2006 06:55 PM ET (US)   Profile for Speedo66   Send Email to Speedo66
While winterizing my 2004 Mercury 60-HP Bigfoot four-stroke outboard I found another fuel filter way down deep not mentioned in the owner's manual. It's under a black cover so you can't see it. However, you also cannot get at it. Same goes for the bottom spark plug, which is just above that filter.
Has anybody changed the hidden filter and the bottom spark plug? If so, what did you have to remove to access them?
Thanks,
Steve
Binkie posted 11-10-2006 10:05 AM ET (US)     Profile for Binkie  Send Email to Binkie
Don`t know about your motor Steve, but I remember on the old inline Mercs I used an open end wrench to remove the unaccesable bottom spark plug.
Speedo66 posted 11-10-2006 11:11 AM ET (US)     Profile for Speedo66  Send Email to Speedo66
Thanks for the tip, Binkie.
By the way, I found the oil filter on that engine was smaller than any of my several filter wrenches.
Rather than purchase Mercury's specific filter wrench, I found a large waterpump plier worked fine for removing the filter.
Steve
Speedo66 posted 11-12-2006 10:57 AM ET (US)     Profile for Speedo66  Send Email to Speedo66
Nobody has changed the filter?
Steve
jimh posted 11-13-2006 09:06 AM ET (US)     Profile for jimh  Send Email to jimh
On most outboards there is a cowling which can be removed to improve access to the lower part of the power head. Often this cowling is just held on with four machine screws. Removing it may make servicing the power head easier.
The Judge posted 11-14-2006 02:45 PM ET (US)     Profile for The Judge  Send Email to The Judge
My bet is with Jim on removing a cowling.
Binkie posted 11-14-2006 03:20 PM ET (US)     Profile for Binkie  Send Email to Binkie
On what motors can you remove the lower cowling without removing the powerhead first. It would be a good idea.Rich
