posted 06-30-2008 08:31 AM ET (US)
Has anyone seen this type of problem? My merc dealer has had the boat for 2 months now and cannot seem to get a handle on the problem even though he has the computer to check it with and has consulted the Mercury Tech in Wisconsin. On choppy days where the boat is bouncing a little the engine will only run for a mile or so and then quit as if someone turned off the key. It will usually start right back up but eventually will not start at all. The last time, it was beeping at me contintiously and would not start once we made it back to the dock. It also seemed to surge as if a cylinder was kicking in and out.If it is flat out I have run it as far as 25 miles without any problems. The first time I took it in, the computer check told him that one of the air injectors was bad and that the starboard temp readings were only 48 degrees even though a manual check indicated both at normal op temps of 150. Replaced the air injector, thermostat & sending unit and no difference - computer check indicated same issue. He thinks the ECM might be bad - the ECM's are $1800. I would spend the money IF I thought that would fix the problems but I am not convinced that this is it. The last time I talked to him, he had it on the computer and running and when he shut it off, the fuel pump would not stop running. He had to disconnect the wiring to get it to quit.
I bought this boat used in the fall of 2007 and it ran without any problems whatsoever although I would get an ocassional 1 beep which I understood to be the system check. It also ran without any of these issues for the month of April and then things have progressivly gotten worse since then.
Any help would be appreciated.
