ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Adding Foam To Engine Cowling to Absorb Sound
Author | Topic: Adding Foam To Engine Cowling to Absorb Sound |
Wasatch Whaler |
posted 07-14-2008 09:55 AM ET (US)
I'm curious if anyone has replaced the foam inside their engine cover with a sound absorbing material like Dynamat? Would Dynamat or a similar product reduce the amount of engine noise? |
TC Goldman |
posted 07-14-2008 11:02 AM ET (US)
I almost did the same thing, but I wasn't sure so I just left the old. Good Question. I hope someone has tried it. |
JMARTIN |
posted 07-14-2008 12:32 PM ET (US)
I replaced my foam some sort of supposedly sound reducing matting. It is silver on one side and looks like carpet felt pad on the other and is about 1/2 inch thick. I am disappointed with the result and it does not shed water as well as foam. John |
jcrwshw |
posted 05-22-2012 03:34 PM ET (US)
Hi Gang. I just finished soundproofing my 1996 Johnson 150-HP--wow what a difference! I used a product similar to Dynamat. The sound level was cut to a point where I don't need ear muffs. http://www.b-quiet.com I would have to estimate a one-third reduction using the butyl rubber and then the 1/2-inch foam on top. Awesome stuff! |
posted 05-24-2012 07:31 AM ET (US)
Sound-absorbing foam will help suppress high-frequency noise transmission, but it has little influence on low-frequency sound transmission. |
davej14 |
posted 05-24-2012 09:03 AM ET (US)
The transmission loss specifications for this product at 125 Hz is stated as 15 db. I would say that is a pretty low frequency and definitely would be noticeable. |
thegage |
posted 05-24-2012 10:04 AM ET (US)
Hey jcrwshw, Which specific b-quiet products did you use? John K. |
posted 05-24-2012 01:05 PM ET (US)
How much thickness (and which product) has a transmission loss of -15dB at 125-Hz? That is a significant change. It would certainly be noticeable. To appreciate sound levels measured in decibels, you can approximate one decibel change as the amount your kid will turn down his music player when you yell at him to turn it down; he turns it down 1-decibel, or the minimum noticeable change. |
davej14 |
posted 05-24-2012 02:24 PM ET (US)
Here is the link, look at B-Quiet Vcomp material which is 3/8" thick: http://www.b-quiet.com/compare.html I haven't tried it personally but based upon the specifications and the first hand experience of jcrwshw, it looks promising. I would like some more first hand accounts if there are any out there. |
posted 05-24-2012 04:03 PM ET (US)
Well, of course the B-Quiet Vcomp material cited has good low frequency suppression; it's lead, not foam. As I said, foam will not suppress low frequency sound. You'll be wrapping your outboard motor cowling with a layer of lead. It weighs one pound per square foot; you'll be adding some weight, too. |
kwik_wurk |
posted 05-24-2012 05:02 PM ET (US)
I have seen big improvements with higher quality sound proofing materials (mine was mylar/foam/vinyl/foam ~1lb/1ft^2). However never done a cowling. I suppose I could try as I have plenty of materials. I re-did 80% of the engine room on one of my I/O's a few years ago. I could not hear the engine running at idle, in fact you had to look at the gauges or the exhaust to see if engine was running. The first time I took the boat out after the insulation job I was shocked that I could hear the noise that comes from the impact zone on the forward portion of the hull. However in sound dampening the most common issue is air gaps. Closing and baffling all airways and gaps is the first big step. I re-did all the gaskets, and drawers so they would seal up and not transmit sound. -- Then I went on and did the insulation. |
davej14 |
posted 05-26-2012 12:34 PM ET (US)
The Vcomp material does not mention lead as part of the sandwich: http://www.b-quiet.com/vcomp.html The Lcomp material does specify lead but also the website states it is not available due the the increased price of lead. Since the weight of each material is the same I have e.mailed the manufacturer for clarification. |
contender |
posted 05-26-2012 05:15 PM ET (US)
I know it would be very hard to control but what about a spray foam used for insulation. This would coat the entire inside with a one piece foam with no voids, cracks, or cuts |
davej14 |
posted 05-26-2012 07:12 PM ET (US)
I don't think spray foam would do much, sound absorbent foam materials are quite different. The other issue I can think of with spray foam is that it would probably not hold up to "under Hood" temperatures and it would age quickly. |
JMARTIN |
posted 05-27-2012 12:59 PM ET (US)
My 1992 Evinrude 200's cowling is designed with air holes. With the original 1/4 inch of foam, it was loud. With my replacement 1/2 inch of foam blanket like stuff, it was loud. It's bare cowling now and it's loud but not louder. John |
contender |
posted 05-27-2012 01:09 PM ET (US)
Dave good point, what about coating the foam with something after the spraying it to the bare cowling... |
pcrussell50 |
posted 05-28-2012 02:48 PM ET (US)
A little OT, but I wonder how many folks who are obsessed with boat motor noise, have added Dynomax or Flowmaster mufflers, or fatter exhaust systems to their trucks? Or louder-than-stock, pipes to their Harley's. More than one, I guarantee it. -Peter |
davej14 |
posted 05-29-2012 09:00 PM ET (US)
Here is some interesting information from B-Quiet in response to my e.mail inquiry: ==================================================== There is no lead in the Vcomp. We have actually discontinued our Lcomp (lead-based material) and we no longer make it. The Vcomp is made out of a dense 1/8" vinyl based polymer barrier with a 1/4" thick foam decoupler. It has a total thickness of 3/8", weighs approximately 1 lb/sq. ft. When using this type of sound deadening product in boats, there are a couple of 1. B-Quiet Ultimate is the best sound deadening product available when it comes 2. B-Quiet Vcomp is the best product when it comes to deadening sound like road, 3. Hliner is good for stopping and absorbing engine noise as well but does not All three products should not regularly get wet but will provide you with Thank you for your interest in B-Quiet sound deadening materials. If you have ====================================================== |
