ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Serious Hull Damage
Author | Topic: Serious Hull Damage |
HarryWhisman |
posted 08-03-2008 11:05 PM ET (US)
Just when I thought I had everything under control. I've spent so much time restoring this 1979 V-20 Outrage and have been having so much fun making 20 to 40 mile dive trips out of Brookings Oregon. I have to trailer the boat 130 miles to get there and have been having wheel bearing problems with the trailer and this time when I jacked it up to fix the blown bearing for the third time, I saw this: http://s121.photobucket.com/albums/o230/Telsta860/ It's about a two foot long crack just forward of the bow roller. I was looking under there trying to figure out how to drop the axle when I saw water on top of it and discovered the damage. The only thing I can figure is maybe I gouged it loading onto the trailer but that doesn't explain the two parallel scrapes down the center so I really don't know how it happened. No way we ran aground. We always load the scuba gear forward so as to get better performance so maybe all the weight, 8 tanks-175lbs lead, mashed it during trailering? I'm sick. So what does one do now?? Somehow buffing it down and laying fiberglass cloth over it all doesn't seem right. It's wet of course. Is there a way to fix this without taking it all apart and flipping it over? Is it time to get a new boat? |
Chuck Tribolet |
posted 08-03-2008 11:53 PM ET (US)
http://s121.photobucket.com/albums/o230/Telsta860/ How come there's now white or grey gelcoat? What's the "bullet hole"?
HarryWhisman |
posted 08-04-2008 12:15 AM ET (US)
The "bullet hole" is the thru hull tube from the fish locker. As for the grey-white gel coat I don't know. Do you think this may be something that was damaged before? I do. Especially now that you've brought it up. When I bought the boat it had a fresh coat of bottom paint so I wouldn't be surprized. |
AZdave |
posted 08-04-2008 02:35 AM ET (US)
I think you need to address the problem. It looks like the crack goes all the way through. I doubt that you caused the problem by poorly balanced loading of the boat. It seems like you would know what you ran into to cause this level of damage.(this is from an Outrage owner with a couple of serious uglies on the bottom of his boat.) I have some really dry space in my backyard, but you need a better idea for drying. When you get it dry, hand laid cloth has a much higher glass content than the typical chopper gun boat hull. Your repair should be stronger than the rest of the hull. Good luck. Dave |
deepwater |
posted 08-04-2008 07:48 AM ET (US)
what it looks like is a trip back to the other owners for an answer about the new bottom paint ,,if he hides things like this on a boat that wont sink what would he hide on a used car or on a job site,, |
towboater |
posted 08-04-2008 08:30 AM ET (US)
I have all the respect in the world for primo condition boats and the care involved to keep them that way. There is a point in all boats life you either start patching up the depreciation and live with it or buy a new boat. I dont see anything there that cant be repaired. Ive worked with cloth and resin just enough to know any work involving the integrity of the hull should be left to pro's who have the right tools and "feel" to apply the resins properly. Pro glass work is as easily recognized as amatuer coverups. |
Plotman |
posted 08-04-2008 05:05 PM ET (US)
Is that keel roller in the picture the limit of how far forward your boat is supported on the trailer? If so, it looks to me like your boat is inadequately supported on the trailer. Your should have side bunks rather than a pair of rollers on each side (though this wouldn't contribute to the damage you show.) I would think that supporting the entire weight of the boat on just two points (your keel rollers) could cause problems over time, especially with any amount of trailering. That said, anything in glass can be fixed. |
slov66 |
posted 08-04-2008 06:41 PM ET (US)
just fixed mine. i bought it used with cracks and indentation on the keel from the roolers ($1000!!!). i called the factory, they said use GET IT DRY- not as easy as it sounds. i tried a few ideas before getting somewhere. i ended up drilling some 1/4" holes in the keel and deck then letting it drain for a few week with a black tarp over it... real hot and dry. that SEEMED to work, but it didn't. i ended up cutting a 6" hole, about 6" deep and putting an inspection plate in. the attracted all the water, made it much easier. then, per the factory, i stuffed the 1/4" holes with long strand fiber glass, sanded, gel coat, done. |
slov66 |
posted 08-04-2008 06:50 PM ET (US)
i also changed the trailer to a bunker style. also not as easy as it sounds, due to the odd hull design. |
HarryWhisman |
posted 08-11-2008 02:58 PM ET (US)
OK here goes. After re-reading the hull repair article in the reference section and mulling it over a while, I decided I could fix this no problem. (well maybe a few problems lol) First I put in an order for the resin used in the article, then kicked back for a week hoping everything would dry out. This morning I got out there with the grinder equipped with a wire brush and commenced to go at it but it didn't take long to realize I needed to use the grinding wheel like the article said. I reached up into the larger hole I had created and was pleased to discover dry foam. Then I got a big nail, bent it over 90 degrees, cut off the head, installed it into my drill and wallowed out the foam behind the crack. Unfortunately once I started tearing out the foam I found it to be completely saturated with salt water. Foam mush. I grabbed the grinder, with a rock this time, and exposed fiberglass all around the hole. I took a rag and a little nail bar and cleaned out the inside of the hole as best I could. This is what I have: I figure now it's time to kick back for another week or so, and at least let the surface area of the foam dry out before continuing. The next step will be to clean it all up with acetone and then stuff in the fiberglass mush. Any thoughts from the pros (or anyone else) would be appreciated.
Chuck Tribolet |
posted 08-11-2008 07:49 PM ET (US)
Did you flush out the salt with lots of fresh water? Salt isn't very strong, so you don't want to try to stick resin to it.
HarryWhisman |
posted 08-11-2008 09:46 PM ET (US)
Fresh water flush will be easy enough...and smart. Thanks! |
RTM |
posted 08-11-2008 10:04 PM ET (US)
Looks like someone, (not you) was the victim of a hit and run! |
dfmcintyre |
posted 08-12-2008 01:11 PM ET (US)
Harry - With the keel opened up like that, I'd think about squirting the non-expanding foam in a can in the void first, prior to laying up glass. Second suggestion is to grind back further for a less acute angle. Third is consider using epoxy vs poly or vinyl ester resin. The shrinkage over time is much less then either poly or vinyl. And keep repeating "It's not rocket science or brain surgery" while doing it... Don |
Bluejay15 |
posted 08-12-2008 09:31 PM ET (US)
This is definitely a previous repair or cover up. You can see in the picture the type of cloth used in the previous repair was bi-ply which was not used in the chopper gun Whaler. I would guess that when it was repaired the guy did not fill the void before applying the glass. Without the glass backing or attaching to a solid surface it will crack when put under stress easily just as you see. I would fill the void with mil fiber or some type of fairing compound. You may have to repeat until it is filled then sand back to maintain the vee and glass over. Good as new. |
HarryWhisman |
posted 08-12-2008 10:12 PM ET (US)
My intension is to fill the void with an isophthalic polyester resin mixed up with some chopped up fiberglass mat. I'm following the method shown under "Whaler Hull Repair" in the Reference section. To tell you the truth I was kind of wondering whether or not to fill the entire void but I guess now that I think about it, that would be the best thing to do; especially considering the location. After that the plan is to sand to create a base for the overlay and then more resin and mat on top. Then I have some fiberglass bondo type filler stuff to fill in any low spots after which I'll sand to shape. After all that--bottom paint. I think maybe I will grind out a bigger area around the hole as df suggested. |
dfmcintyre |
posted 08-12-2008 10:13 PM ET (US)
Bluejay - - You sure that bidirectional aka woven roving was not used for strength at the keel? Don |
Bluejay15 |
posted 08-12-2008 10:23 PM ET (US)
Good question. I may be wrong about the keel. I just haven't seen any in the whaler I have. |
Bluejay15 |
posted 08-13-2008 07:13 PM ET (US)
Does anyone know for a fact if older whalers used bi-ply in any part of the boat? Or any type of cloth besides chopped mat for use in a chopper gun? I have made repairs to the front keel on my 15 as well as other parts of the hull and did not see any. |
towboater |
posted 08-13-2008 07:36 PM ET (US)
Yo Harry. Fellow NWer. Born in North Bend. Sometimes I wonder if repairing a 25 year old whaler to perfection (via CW specs) is nessesary? I removed the foam inside the bait well of a 22 ft Guardian Divemaster two years ago. Id say the bait well holds about 20 gallons of foam volume and I ended up with less than a gallon of water. rounds off to 5%. Then this boat burned. I got a close look at the innerds. Take a plastic gallon jug. My point is, 5% waterlogged is a small factor. Now rip gash in the jug. Dump it in water. Let it sit 5 months and weigh it. OK? I dont know all the names but I do know there are plenty of sealers nowdays that work with water. After that, put 3 layers of roving and mat over it. Gob some bottom paint and away you go. Sorry for not proofreading and correcting, |
pglein |
posted 08-14-2008 01:21 PM ET (US)
I am pretty sure woven roving was used extensively in stress points of the hull in many models over many years. To not use it would be negligent. Just becuase you "haven't seen it" doesn't mean it's not there. If you haven't made substantial repairs to the hull of the same year and model Whaler in the area in question before, you can by no means say definitively that it it not original. Small fiber woven roving is called "boat cloth" industry wide because it is widely used in boat construction. I would be very surprised if Whaler varied that much from the industry standard. Whaler hulls are not "chopper gun" hulls. There is undoubtedly some use of a chopper gun to add thickness in certain parts of the hull, but it is largely a boat cloth and matt layup. I have observed this in hull repairs I've made to my '71 13', and as a former fiberglass fabricator, I think I speak with a little authority on the subject. It is common for amateurs making repairs to mistake a matt layup with chopper-gun application, as, after curing, they look very similar. However, the matt layup offers far superior consistency and overall strength, especially when paired with some woven roving. Note also that just because you see the random fiber appearance of a chopper gun or matt layup while sanding to make a repair, does not mean that roving was not used in the layup. Most layup schedules include several different types of glass. For example. A layup may include two layers of matt, followed by a layer of boat cloth, followed by a layer of 1/4" roving, followed by another layer of boat cloth, followed by 3 or 4 more layers of matt, and then a given thickness using the chopper gun for wear resistance. You'd have to grind pretty far through that glass to discover the roving, and if you weren't watching for it, you might not see it. |
Bluejay15 |
posted 08-14-2008 05:12 PM ET (US)
Everything you said is correct, but I would really like to know for a fact if and where any bi-ply was used besides mat in older Whalers. I have done plenty of fiberglass repair and fabrication myself albeit on an amateur bases on other boats besides Boston Whalers and it is easy to see other types of cloth like in the pics I am providing, but I have not seen this in the Whaler I have. The thing is Boston Whaler has a unique unibond construction and it would be good for HarryWhisman and anyone else to know for their repair jobs. I know when I do repairs I like to know if I’m working on something that has been previously repaired and why it has to be repaired, so the problem is resolved and will not happen again. This scenario could have happened because of delamination from water intrusion causing a void which eventually cracked or different possibilities. I don’t know I could just be reading to much into this and opening my big mouth again. But now I really would like to know for a fact not just speculation like I did if and where bi-ply was used. I know where it is not. Maybe with the unibond construction they did not use it.
davej14 |
posted 08-15-2008 01:55 PM ET (US)
Fixed links: http://i221.photobucket.com/albums/dd128/dixtover/1b.jpg |
HarryWhisman |
posted 08-19-2008 01:09 PM ET (US)
Here we go... Two days ago I recleaned inside the gouge as best I could with a bent screwdriver and an acetone soaked rag. I cut off a section of mat and pulled it apart to where I had a pile of fibers and then spent a little time cutting them into smaller pieces. Mixed up a cup of resin and stirred in what I thought was a good amount of fiberglass to make the mush. Took a stir stick and mashed it all into the gouge filling about a third of the hole. What I learned: Some of the dripping resin landed on my arm. Long sleeve shirt next time. That's a big hole and it's probably going to take a lot more than the quart of resin I ordered and the one pint mixing cups are too small.
This morning I went at it again. This time I spent a lot more time cutting up the glass mat. What I learned: Always wear a long sleeve shirt, gloves, mask and a sock over your head when chopping up glass mat. Otherwise you'll look like you're covered with your daughter's sparkle makeup. This time I mixed up two cups of resin in a quart mixing cup and added a lot more glass. Put down some wax paper and went at it, stuffing the glass mush into the gash with a stir stick and my nitrile gloved hands. I put some of the mush into the low places left from the first application. What I learned: Iso resin melts nitrile gloves. The glove didn't immediately melt through or anything but after about a minute it began to sag and when I was through I had resin on my fingers. One needs to get it right the first time because filling the low places with mush on the second pass is difficult. Perhaps if I had ground it down first it would have worked better. You can see from the picture the front doesn't look as good as the back. http://i121.photobucket.com/albums/o230/Telsta860/glassfilled.jpg http://i121.photobucket.com/albums/o230/Telsta860/glassfilledfront.jpg
kwik_wurk |
posted 08-19-2008 02:18 PM ET (US)
To prevent the excessive drippy epoxy use a little filler in the resin. (Add filler to go from honey to peanut butter consitency.) I add the resin and filler together and mix first, then I let it sit for a couple hours so all the air bubbles rise. Then you can add the hardener and go to work. And yes working on a keel (under the boat) is not the cleanest thing to do. But in all, it looks like you'll have a solid patch (and no one will really know). I would suggest a water barrier type surface coat (then bottom paint). I would be nervouse with a fiberglass bottom paint finish. You really want to make sure that the interface between your new patch and old hull doesn't seperate and start absorbing water. I am not sure what type of "bondo" material you are using, and it may do the job. Good luck... |
Hunch |
posted 08-19-2008 04:17 PM ET (US)
Hindsight is 20 20 Westmarine carries a Polyester Structural Filler, made from chopped glass and resin. Filling that gouge is the weakest part of the repair but serves as a mold for the shape. The glass work is where your strength will come. Be sure to layup your glass at least 6" on each side of the keel. Be sure to use laminating resin and not finishing resin for the 1st few layers. Stagger the overlay so the layup tapers to the hull. I would use 3 layers of 12 oz cloth or 2 layers 12oz biaxial if you can find it. Hope this helps some Bob |
HarryWhisman |
posted 08-19-2008 05:10 PM ET (US)
Ground down the filler patch and ground out beyond the hole a little further. http://i121.photobucket.com/albums/o230/Telsta860/Grind.jpg
http://i121.photobucket.com/albums/o230/Telsta860/duraglass.jpg
Casco Bay Outrage |
posted 08-19-2008 08:09 PM ET (US)
Harry Type [url] before the beginning of your link and [/url] at the end of the link and they will show up like this: http://i121.photobucket.com/albums/o230/Telsta860/Grind.jpg http://i121.photobucket.com/albums/o230/Telsta860/duraglass.jpg |
HarryWhisman |
posted 08-19-2008 08:37 PM ET (US)
OK!! I leveled out the inside patch and exposed even more fiberglass on each side. Wiped it down with acetone, mixed up 1/2 cup of resin and layed on three strips of mat; the first being 23" X 1 1/2" and the next two successively bigger. I figure that's enough for today. http://i121.photobucket.com/albums/o230/Telsta860/Glass1.jpg I have two more strips cut and I'll put that on with my last 1/2 cup of resin tomorrow. Note: I bought my mat from M&M Auto Paint here in Medford where I originally asked for 6oz, but the guy had no idea what I was talking about. The mat they have isn't marked as to how heavy it is. Maybe it's thinner? I figured I could just keep laying it on until I had enough? I don't have enough mat left to cut any more strips so I could order some different stuff from the big city if I needed to. I'm amazed that this actually seems to be working. |
Plotman |
posted 08-22-2008 03:23 PM ET (US)
Looking good Harry- It really is like paper mache for grown ups. Glasswork is messy and nasty, but not hard. Plus, you really can fix any screw ups by grinding it down and starting over... |
HarryWhisman |
posted 08-31-2008 08:24 PM ET (US)
Well I got side tracked fixing damage I discovered on the keel in the back. Documented it all under "More Serious Hull Damage". Now that I'm back to the bow I've decided I'm done, except for the sand, primer and paint. With the glass underneath and the three layers of mat on top, it's already a little high so that's it. It seems really strong. |
HarryWhisman |
http://i121.photobucket.com/albums/o230/Telsta860/Glass1.jpg |
