posted 08-09-2008 04:26 PM ET (US)
Hi everyone. A friend of mine has a 2003 Mercury Optimax 90. It has only run about 50 hours and she has a problem that all Mercury specialists have not been able to solve. [The 2003 Mercury Optimax 90] starts and idles fine. I can start running at below 3,000-RPM for five minutes just to leave the harbor. When opening the throttle the engine reacts fine at first. It runs OK for some minute (even at high RPM) and then suddenly looses all power. If I throttle down to half, it can resume normal running, but not always. I have found that if I am running at about 3,000-RPM and starts to tilt the engine up or down just a little it can start to oscillate wildly, changing its speed between 2,000 and 3,000-RPM just like going on-off-on in a rapid pattern. The only way to get rid of it is throttling down to idle.
When the engine starts to go badly, the high pressure fuel pump (I think it is that in the port side alloy box with the fuel pump on, and fuel lines to the fuel rail) to sound badly, it is making a squeeking noice. If it is sounding like this because it is lacking fuel, or if the fuel pressure goes down because of a faulty pump.
I have also some strange things on the SmartCraft Gauge. It has 4 warnings: PITOT, TRIM, FUEL EMPTY and OIL EMPTY. When scanning the different readings I get 0 in speed, 0 in oil temperature and 0 in oil pressure. In reality, the oiltank is full, the fuel tank is half and I am making a good 25-knots. I have no manual to check what these warnings mean.
To this date my friend had payed over $1,500 to a Mercury service center, but no difference. The engine is still not working. They have cleaned tanks, changed fuel lines, filters, etc, but seem to not know what to do.
I think it is either a fuel problem or a sensor problem that tricks the ECM to handle fuel incorrectly.
Does anyone have an idea, I know a lot of engines, have designed my own EFI-system etc, but I do not know that much about this particular engine.
I hope someone can give me a clue.
Best regards
Nisse / Sweden
