posted 10-21-2008 11:10 PM ET (US)
I have the 21 Outrage's little brother the 20 Outrage. I have also spent a good amount of time on a 24 Outrage of the same vintage. Water can get into the bilge a number of ways.1. Water can run between the splash well hatch and or the fiberglass piece that holds the splash well hatch. I've seen the 5200 loosen up and allow water to drain into the bilge. The bilge access hatch back there may need a new gasket.
2. The little deck plate/access plates may need new gaskets. These will allow water to run down the top of the fuel tank into the bilge.
3. The in deck fish boxes my be leaking where the pump out fittings are installed.
4. If you have the livewell/leaning post, washing that out will allow water to drain through the hole that the livewell drain hose goes through.
5. If any of the 5200 sealing the fuel tank cover (aka the deck) is broken then water can drain down onto the fuel tank then into the bilge.
That's about all I can think of.
