ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Rigging Digital I-Command Gauge
Author | Topic: Rigging Digital I-Command Gauge |
splishsplash |
posted 10-30-2008 07:44 PM ET (US)
I riggign my boat with an E-Tec and am looking for instructions for hooking up the I-Command. It looks simple enought but I want to be sure to do it right. Thanks |
seabob4 |
posted 10-30-2008 07:48 PM ET (US)
Do you have all the components, i.e. tees, backbone harness, termination resistors, etc? Are you going to have an oil tank sensor, fuel tank sensor, GPS antenna? More info on what you want to do would be helpful. |
splishsplash |
posted 10-30-2008 08:06 PM ET (US)
I'm pretty sure I have everything needed. I have the water pressure setup, fuel level setup. I am only running one guage and it is a small console on the boat and I do not want it to get cluttered. |
splishsplash |
posted 10-30-2008 08:07 PM ET (US)
Do you have to use the lowrance GPS antenna or can I run it off of my Garmin GPS? |
seabob4 |
posted 10-30-2008 08:22 PM ET (US)
As long as you have the latest antenna. GPS 17x NMEA 2000. If you have the older GPS 17 or 17X, that antenna is 0183, won't communicate with the BRP network. |
SJUAE |
posted 10-31-2008 12:59 AM ET (US)
splishsplash This is a useful utility to check your design http://www.evinrude.com/evinrudepublic/i-command/ rgds |
seabob4 |
posted 10-31-2008 07:45 PM ET (US)
Good publication that BRP has put out, but didn't see a component section, as far as all the "hardware" one needs to rig an etec for I-command. That was the question I was asking. |
posted 10-31-2008 10:56 PM ET (US)
This is a topic for SMALL BOAT ELECTRICAL. You can find the literature you need there: |
SJUAE |
posted 11-01-2008 04:39 PM ET (US)
Network design tool lists all the parts you need and checks it's ok Regds |
