posted 02-12-2009 12:48 AM ET (US)
Power trim systems contain two distinct segments: the electrical portion and the hydraulic portion.The electrical portion has straightforward and simple circuitry. With a basic understanding of electricity and minimal test equipment you can assess the electrical operation. Switches control relays that run a motor or two.
The hydraulic system is substantially more complex. Other than checking the fluid level and making a careful visual inspection for leaks, there is not much that can be done simply. If the engine drifts down from the tilted-up position, you likely have a check valve which is not operating properly. These valves are typically contained in an internal assembly, and you generally cannot easily repair or replace them without tearing down the assembly.
If fluid has escaped from the system and been replaced with air, you will see erratic operation. Often re-filling the system to the proper fluid level, then operating the ram through its entire range a number of time with the filler cap removed will permit the system to bleed air from the lines.
Your owner's manual should give you advice on any procedures to use when refilling the hydraulic system with fluid. Be sure to use the proper fluid as recommended by the engine manufacturer.
If you decide to dig deeper into the hydraulic system, you will probably need to buy the factory repair manual for guidance.
