Topic: OMC single binnacle with Yamaha 115 4 stroke
mongey |
posted 03-06-2009 11:59 AM ET (US)
I purchased a used montauk whaler console and it has a single OMC binnacle mount on the console and is in good shape as the console was stored inside and has seen almost no use. I have a 115 4 stroke Yamaha (currently on a 17ft. Bayliner with side mount Yamaha controls and cables. I plan to put the Yamaha on the Whaler and was wondering if the OMC binnacle will work with the Yamaha cables and motor. Any help with modification kits from teleflex or other info. is much appreciated. Thanks
seabob4
posted 03-06-2009 07:51 PM ET (US)
You'll need to run universal cables in the Montauk and buy the Teleflex adaptors for the binnacle. Make sure what "direction" the yammi is as far as shift/throttle (push/pull), and rig the binnacle accordingly. |
