posted 03-08-2009 07:11 AM ET (US)
Thanks, Tom - So the water lays there? I suppose not much will lay there, nor I suppose will it hurt anything...?
Is there a need then, for the floor caulking on its edges? Currently there are 2 gas line holes; I plan on plugging one nipple at round tank lid and running one line to motor; the other hole in fiberglass, then, would be open to right rear bilge (~12" square) access, allow water to drain out of tank area. Is that a good plan?
Would it hurt or be good for me to drill a hole from the tank area into the 12x12 bilge hole, and professionally install a brass drain? Seems like that would be a good thing.
Also, what is the T-Shaped channel for? In Jason Richer's photos and article in Cetacea:
http://continuouswave.com/whaler/reference/centerDeckRepair.html
....he mentions at one of the photos: "Fuel Line Fill and Vent Hoses, ....At the forward end of the fuel tank the large fuel filler hose and smaller tank vent line attach. The T-shaped channel molded into the hull is interesting. Its precise purpose has not been deduced. Also notice the small white drain linking the central cavity with this port side channel.
