posted 04-28-2009 12:30 AM ET (US)
OT,
don't get your panties in a bunch like I did. My console was shot, interior shot, exterior shot etc. Things aren't usually as shot as they seem on these older beauts. I went crazy thinking i had to wet sand for the next 3 months starting at 600 grit up to 2200. What I discovered (after erroneously sanding half the inside with 400) was that the rust stains and others can be wet sanded with 600 keeping the working area as small as possible, and then purchase the porter cable 97336 (best buy ever!) and follow this thread because the recs are dead on! http://continuouswave.com/ubb/Forum3/HTML/000680.html
all you really need are a few white and orange polisher pads that you can by on Meguire's or other sites and the hook and loop merely means velcro backed for easy to use velcro polishing pads. The white one actually doesn't need the backing pad as it comes with one that is "integral" or built in to the pad.
Then follow threads on gel coat repair with the kits etc. My take is that it's easy..and at times fun to get carried away but try to keep it in perspective and take one bite at a time. Don't feel the need to start tearing up every crack with a can opener when you might find a lot of them disappearing from view with the detailing recs.
Heres a bunch of threads I've been saving up that have helped me...hope they make it easier for you. Good luck amigo....I'm still working on mine and hoping to launch her in a month.
By the way...there are a lot of great people on this site with very friendly and helpful advice....utilize them! They would like nothing more than to see another classic resurrected!
http://www.twincitiesmarine.com/
http://continuouswave.com/ubb/Forum3/HTML/001666.html
http://www.bimi-teetop.com/index.html
http://continuouswave.com/ubb/Forum6/HTML/000568.html electric
http://www.defender.com/
www.boatfix.com
http://continuouswave.com/ubb/Forum3/HTML/003475.html rps z legs
http://www.discountmarinesupplies.com/Above_Deck_Fuel_Tanks-TEMPO_11_GALLON_BOSTON_WHALER_FUEL_TANK.html
http://www.spectrumcolor.com/catalog.htm
http://continuouswave.com/ubb/Forum3/HTML/000985.html
http://continuouswave.com/maintenance-logs/epoxy/
