posted 06-10-2009 08:47 AM ET (US)
In many cases the alarm system of these older motors uses a WIRED-OR arrangement of the sensors. There is only one lead controlling the alarm sounder operation. Any sensor can trigger the alarm by pulling the voltage on the alarm lead to ground. Each sensor typically has some sort of distinguishing cadence of sounding the alarm to identify it as the source.To test the alarm system, locate and disconnect all sensors from the alarm sounder. This isolates the alarm system into two sets of components, the sensors and the alarm sounder. If the alarm still sounds, the sounder is defective. If the alarm is silenced, reconnect the sensors one at a time. The bad sensor will cause the alarm to resume.
If the alarm sounder is made as an integral part of another assembly, it may be possible to reconfigure the system with a new sounder that is a separate component, instead of replacing the whole assembly.
If the sounder is part of the ignition key switch assembly, perhaps some water has intruded into the assembly. This may have created some corrosion which is causing the false alarm.
