ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods 1997 Mercury 135 offshore compression
Author | Topic: 1997 Mercury 135 offshore compression |
surferkevman |
posted 06-28-2009 12:22 PM ET (US)
I just had the compression checked and it was 100 per cyl. Is that about right? Thanks. |
posted 06-28-2009 02:52 PM ET (US)
What you probably mean is you that you measured the maximum pressure in each cylinder and found it to be about 100-PSI. Atmospheric pressure, nominally 1-BAR, is about 14.7-PSI. Compression ratio can be estimated from Pressure at dead top center = 1-ATM X (CR)^1.4 where CR=compression ratio: Thus CR^1.4 = 100/14.7 Your compression ratio is 3.93:1 Cf: http://en.wikipedia.org/wiki/Compression_ratio Measurement of cylinder pressure relies on the accuracy of the gauge being used and on the technique and conditions of the measurement. There are many variables in the technique to measure compression. A general guide to making cylinder pressure measurements is given in http://continuouswave.com/whaler/reference/outboardCheck.html See the subheading Compression Check The usual metric for assessing the condition of the engine is to compare measurements among the cylinders. If the variation is less than 15-PSI your engine is in good shape. |
surferkevman |
posted 07-01-2009 09:26 AM ET (US)
Thanks Jimh, Have a nice summer whereever you are. |
