ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Working with Plexiglas
Author | Topic: Working with Plexiglas |
R T M |
posted 07-03-2009 08:22 AM ET (US)
Very simple material to work with. The first 3 pics are of the finished piece (it will keep water from spilling over the transom of my raceboat. I used .20 gauge Plexiglas. http://i27.photobucket.com/albums/c191/floridaboy2053/plexiglass/ 100_1066.jpg http://i27.photobucket.com/albums/c191/floridaboy2053/plexiglass/ 100_1069.jpg http://i27.photobucket.com/albums/c191/floridaboy2053/plexiglass/ 100_1069.jpg Becuase of the many angles I had to make a mold or a form to clamp the plexiglass into as I heated the bend points one at a time. http://i27.photobucket.com/albums/c191/floridaboy2053/plexiglass/ 100_1053.jpg first I made a cardboard pattern, and then cut the plexiglass to the pattern http://i27.photobucket.com/albums/c191/floridaboy2053/plexiglass/ 100_1054.jpg http://i27.photobucket.com/albums/c191/floridaboy2053/plexiglass/ plexiglass-1.jpg Then I finished the edges, first with a belt sander, then with an orbital sander, and then hand sanded with some http://i27.photobucket.com/albums/c191/floridaboy2053/plexiglass/ 100_1063.jpg http://i27.photobucket.com/albums/c191/floridaboy2053/plexiglass/ 100_1060.jpg rich/Binkie |
R T M |
posted 07-03-2009 08:31 AM ET (US)
Here is the plexiglas clamped in the mold http://i27.photobucket.com/albums/c191/floridaboy2053/plexiglass/ 100_1061.jpg Another pic of the plexiglas installed http://i27.photobucket.com/albums/c191/floridaboy2053/plexiglass/ 100_1070.jpg rich/Binkie |
alfa |
posted 07-03-2009 12:14 PM ET (US)
Nice article Rich. Thanks for sharing. Alain |
high sierra |
posted 07-03-2009 05:02 PM ET (US)
Very well done. high sierra |
Newtauk1 |
posted 07-03-2009 09:48 PM ET (US)
Wow. You make it look easy. I imagine there are plenty of projects that could incorporate your process. Thanks for sharing. |
PeteB88 |
posted 07-04-2009 11:30 PM ET (US)
Rich - How do you cut the stuff? I tried to cut a piece today (trim actually) w/ sabre saw and it kept melting back and sealing the cut like plasma or something. What's the trick? Pete |
alfa |
posted 07-05-2009 01:48 AM ET (US)
Put adhesive tape under the plexiglass before cutting. my 0.02 |
R T M |
posted 07-05-2009 07:14 AM ET (US)
Pete, |
R T M |
posted 07-05-2009 07:41 AM ET (US)
Sorry, this computer has a hair trigger. Use a blade that's meant to cut plastics. Also, use alfa`s idea. tape on both sides. You will get a little chipping, but no matter. Clamp your belt sander in a vice and run the edges over it Use 60 grit belt. Then slightly bevel the edges to finish it and get rid of the chips with your orbital sander and 120 paper. Then rub down the edges with some 1000 paper, dry. Don`t touch the flat surfaces with sandpaper, or its curtains. It may be possible that the blade you are using may be too fine if it is melting the plastic. The blade I used was a Bosch T123X3 from Home Depot. You may not have a Bosch saw, but look at the blades to get an idea of the size of the teeth. I`m trying to figure out how to make a curved windshield for my '59 tail fin boat. I`ll try to make a mold out of thin Masonite or counter top grade Formica and lay the glass over it and heat it and see if it will lay down over the mold. I`ll try a small piece first. The windshield will be about 5 feet long. Any used ones I find are not in great shape and are expensive. Working with Plexiglas is easy and kind of fun in a way. rich/Binkie |
