Topic: fuel gauge wiring
misterwood |
posted 07-05-2009 12:14 PM ET (US)
i need wiring diagram for a fuel gauge, it is marked on back L-S-G-I,the tank has two connections not marked. thanx
outragesteve
posted 07-05-2009 05:57 PM ET (US)
Typically, fuel gauges have those markings: "L" is for the light, if equipped, "S" is the sender from the tank, "I" is ignition/12 volts, "G" is ground. On the sender, usually there are 2 connections: A ground and the sender, usually an unsulated connection in the middle of the sender. Good luck! |
misterwood
posted 07-05-2009 10:19 PM ET (US)
thanks alot, misterwood |
posted 07-06-2009 10:05 AM ET (US)
PLEASE use the discussion area SMALL BOAT ELECTRICAL for this topic. |
