  Anode for Merc Optimax: Zinc vs Merc's Aluminum
Author Topic:   Anode for Merc Optimax: Zinc vs Merc's Aluminum
ivansfo posted 07-21-2009 02:15 PM ET (US)   Profile for ivansfo   Send Email to ivansfo
Just curious what everyone would choose if you had to replace the anodes on your Merc outboard.
For strictly saltwater use, would you choose Mercury's aluminum alloy anode OR would you go for regular zinc? If zincs are less noble than aluminum, wouldn't the better choice be the zinc?
Rust and crevice corrosion is starting up on my 2001 Optimax motor. The anodes are the original ones so I want to replace them. Just not sure if I should go OEM or replace with pure zinc.
Thoughts?
Buckda posted 07-21-2009 02:42 PM ET (US)     Profile for Buckda  Send Email to Buckda
OEM alloy anodes will corrode FASTER and provide better protection than traditional zinc....that is why Mercury invented them.
I would go OEM....especially in fresh water. But in Salt - you will replace anodes faster than if you used zinc. Who cares - the reason they're called sacrificial anodes is because they are designed to be used up and replaced. Buy the OEM.
K Albus posted 07-21-2009 02:56 PM ET (US)     Profile for K Albus  Send Email to K Albus
According to West Marine, for strictly saltwater use, aluminum anodes provide the same protection as zinc, but last longer. See: http://www.westmarine.com/webapp/wcs/stores/servlet/westadvisor/10001/ -1/10001/Galvanic-Corrison-Protection.htm
Tom W Clark posted 07-21-2009 03:08 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I would (and do) use Mercury's OE anodes. They are a mixture of zinc and aluminum. The anodes are made for Mercury by Canada Metals.
You can buy Canada Metals anodes at your local chandlery. They look just the same but they are not the same mixture of alloys.
Remember, whatever anodes you choose to use, use the same type on all locations. You do not want to mix different types of anodes because the least noble will do all the "work".
ivansfo posted 07-21-2009 03:55 PM ET (US)     Profile for ivansfo  Send Email to ivansfo
Thanks for all the suggestions. I just returned from West Marine to see what they have in terms of anodes.
They have a Mercury (Quicksilver) section of OE parts . Found the OE anodes for my motors and looked at the packaging. Thinking they are made by Canada Metals for Merc, they are made in Canada right? The package I saw says "Made in China" with no markings on the package about Canada Metals. Maybe Merc is outsourcing to another company in China now? Or does Canada Metal have a plant in China?
And as K Albus noted, this is what West Marine says about anodes:
"If you are a saltwater boater, you should install zinc anodes to prevent galvanic corrosion on the engine and underwater parts of your boat. Look for aluminum anodes as a possible replacement because they last longer while providing the same level of protection as zinc."
My interpretation is WM is first recommending zinc for saltwater boaters for optimal protection. Then aluminum as an alternative if you want something that last longer and almost as good as zinc. Price wise, the aluminum anodes cost more than zinc anodes manufactured by Canada Metals offered at West Marine.
Now the skeptical side of me wonders how can Merc sell an aluminum/zinc anode which is cheaper, better, AND last longer than plain zinc? Sounds too good to be true. And all the old salts I have talked to says to use proven zinc for saltwater boating.
My boat is trailered so I'm not worried about which wears out faster. I just want to best protection for my motors.
Tom W Clark posted 07-21-2009 07:46 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I have no reason to assume Canada Metals manufactures their anodes in Canada. Many companies manufacture their products China for obvious reasons.
"...the aluminum anodes cost more than zinc anodes manufactured by Canada Metals offered at West Marine"
"...how can Merc sell an aluminum/zinc anode which is cheaper, better, AND last longer than plain zinc?"
There seems to be some contradiction there. Can you explain?
How much do the parts in question cost?
ivansfo posted 07-21-2009 08:23 PM ET (US)     Profile for ivansfo  Send Email to ivansfo
Tom,
I was comparing 3 anodes offered at West Marine. There are actually 4 but I'm not considering the one made of magnesium. Looking at the West Marine list prices for the wedge pocket anode, here's what they cost.
First time I see I Merc part cost less than non-OE!
MFG Part#
CM826134KITA Aluminum anode kit by Canada Metals $29.99 (~$15 each)
CM826134Z Zinc anode by Canada Metals $13.99 each
826134Q Aluminum/Zinc anode by Mercury Marine $8.79 each
I speculate Mercury's motivation to come up with a aluminum/zinc alloy is to streamline parts inventory. And while they had such a product, why not patent it. Its much more cost effective for them to offer a single general-purpose anode where they can slap it on every outboard they sell and not worry about whether the customer will be using the motor in fresh, brackish, or saltwater. This is why I'm leaning towards a regular zinc anode as my replacement.
Ivan
jimh posted 07-21-2009 11:01 PM ET (US)     Profile for jimh  Send Email to jimh
Tom W Clark writes:
"Remember, whatever anodes you choose to use, use the same type on all locations. You do not want to mix different types of anodes because the least noble will do all the 'work.'"
Tom--That is an excellent point which I do not recall having been made before. Thank you.
L H G posted 07-22-2009 12:52 AM ET (US)     Profile for L H G
As far as Mercury engines are concerned, the West Marine comments are baloney. Mercury's aluminum alloy anodes came out in 1991, I believe, and Mercury claims them to be 50% more effective in controling galvanic action than the old fashioned zinc. They are much lighter in weight and a more silver color. I have used them exclusively since that time, and from my salt and FRESH water boating experience, I can say they are MUCH more effective, and sacrifice faster both in salt and fresh. I believe they are the best you can buy. And my engines are totally corrosion free, two dating back to 1985.
In Mercury's advertizing literature, they claim to have the exclusive rights to this alloy, as for years the other manufacturers only had access to zinc. Who owns the Patent, I don't know. Maybe Mercury, and Canada makes them for them, maybe Canada and Merc bought the exclusive rights.
If you own a Mercury or Mercruiser, don't even consider buying anything but the OE anodes. In freshwater, they also work better than those magnesium ones West is selling. I have tried them, and they barely sacrifice at all.
jimh posted 07-22-2009 06:50 AM ET (US)     Profile for jimh  Send Email to jimh
I am not surprised to learn that Mercury has put effort into developing special sacrificial anodes to protect their gear cases from galvanic corrosion. Their gear cases have a history of problems with galvanic corrosion, particularly with their BRAVO III duo-prop gear case, and it seems entirely reasonable that they'd have formulated their own alloy for a sacrificial anode to protect them. Mercury previously had an active electrical system product which they used on their gear cases to help prevent galvanic corrosion of the gear case. The trade name for it was MerCathode.
The problem with galvanic corrosion is influenced by the mount of other metals in the water. If you have a large stainless steel propeller you may need more protection than if you have an aluminum propeller. Mercury also found that use of stainless steel for some internal components of the gear case was causing problems and necessitated special sacrificial anodes to be installed to suppress galvanic corrosion.
One consideration in providing protection against galvanic corrosion is controlling the voltage potential that exists between the metals. It may be possible to provide too much protection by creating too much voltage potential between most noble and least noble metals, and by having too much surface area.
It makes perfect sense to me to use the manufacturer's recommended anodes. We are talking about a miniscule cost difference among OEM and non-OEM anodes (and apparently not even a savings) compared to the replacement cost or repair cost of the engine, and it is unlikely that there is much advantage to be gained by using non-OEM brands. This is particularly true during the period when an engine is covered under warranty against corrosion. I suspect that if non-OEM sacrificial anodes were used to replace the OEM sacrificial anodes, the manufacturer might have reason to deny warranty coverage, and probably rightfully so.
Because Boston Whaler boats are typically always a fiberglass boat, their hulls are not involved in the galvanic corrosion. However, boats with aluminum drive brackets or with aluminum engine set back brackets will have a lot of additional metal in the water besides the engine itself. It is not surprising that boats with these added metal components in the water might have different experiences with galvanic corrosion that an all-fiberglass boat like a Boston Whaler.
jimh posted 07-22-2009 06:53 AM ET (US)     Profile for jimh  Send Email to jimh
I don't see any reasonable basis to make the conclusion that use of Mercury OEM sacrificial anodes on non-Mercury motors will provide any special benefit, however, I would be open to a discussion which could explain how that might occur and which provided some underlying electro-chemistry to explain it.
Peter posted 07-22-2009 08:00 AM ET (US)     Profile for Peter  Send Email to Peter
Another piece of advice: Make sure that the sacrificial anode (whatever brand or material you decide upon) is electrically bonded to the motor it is intended to protect. You could have a sacrificial anode made from Mercury's proprietary Unobtanium and it would do absolutely no good if its not electrically bonded to the motor. You can check for electrical bonding doing a continuity check with a multi-meter.
ivansfo posted 07-22-2009 03:01 PM ET (US)     Profile for ivansfo  Send Email to ivansfo
LHG, I don't think West Marine's advice is complete garbage. They are being general so it could apply to all brands of boats and motors. So they try explain the applications between the 3 traditional types of anodes (pure magnesium, pure zinc, and pure aluminum).
It would probably confuse their readers if they included a blurb about a 4th type of anode made of an aluminum/zinc alloy sold by Mercury and only available for Mercury engines. And this is exactly what I'm trying to figure out here. What application is best for this 4th type of anode.
Current state of anodes on my 2001 Optimax. Operated in saltwater only. Rinsed after each use and boat sits on a trailer. These are the original ones that came with the new motors.
http://home.sanbrunocable.com/~ivanlum101/boat/anode1.JPG
http://home.sanbrunocable.com/~ivanlum101/boat/anode2.JPG
Now I feel I'm over researching this whole issue. I'm just going to pick one type and swap them out. Afterall my motors have been more or less corrosion free for the first 6 years of ownership.
Tohsgib posted 07-22-2009 03:27 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Zinc is what everyone used to use. Many now use aluminum in salt water and have good results mainly because they are softer than the pot metal outboards are made of. I had alum anodes on my 17 and they did not do a good job due to the fact I had an aluminum jackplate and it kinda ate both. Went back to zinc and problem solved. Magnesium is great for fresh water. People by me were having problems with SS props and aluminum anodes as it was eating the housings away for some reason. Changed to magnesium and alum props and problem went away. They would however only get about 6 months out of the anodes and in salt water they did not protect much. Kinda have to experiment or go with what you had being it worked.
ivansfo posted 08-05-2009 08:33 PM ET (US)     Profile for ivansfo  Send Email to ivansfo
First off, I appreciate all the responses. I've decided to experiment a little here as suggested by Tohsgib. You all have confirmed my feelings that there is nothing wrong with using zinc anodes for boats used exclusively in saltwater. So I purchased pure zinc anodes online from a place called boatzincs.com. They came fast and look to be good quality. They are marked "Reliance" and made in Canada.
After removing the old Merc anodes, I found there to be much corrosion at the bolt holes and areas where the anodes make contact to the motor. So much that I believe they were not making a good electrical contact rendering them useless. And the old anodes weigh only a fraction of the new zinc anodes. The difference in weight can be attributed to aluminum vs zinc but I think also a lot of the weight was gone due to wear.
So those with anodes over 5 years old, you might want to pull them off for inspection. I'm glad I did the swap out.
L H G posted 08-05-2009 08:55 PM ET (US)     Profile for L H G
Ivansfo - I completely fail to understand your logic!
You state your Mercury Optimax has had the original Mercury anodes on it for six years, and say:
"Afterall my motors have been more or less corrosion free for the first 6 years of ownership."
Then you switch to less protective aftermarket (old fashioned, old technology) zinc anodes? It seems to me "if it ain't broke, don't fix it" The reason your saltwater use engine has been totally corrosion free is, first of all, the high quality aluminum alloy and EDP paint system Mercury uses, and secondly, the exclusive Mercury aluminum anodes.
The reason your original anodes look pretty eaten up is that is exactly what you want. I have a pair of 1984 Merc 115's, and a 1988 150, both of which were manufactured before the aluminum anodes were invented, and came from the factory with the old style zinc anodes. They barely sacrificed at all, hence giving little protection. When I upgraded to the new style, protection greatly increased in salt water and freshwater use, and they look like yours do after a few years. Incidentally, Mercury says to replace anodes when they are 50% consumed.
I will say those zincs will last the life the engine, and you won't ever have to replace them again.
ivansfo posted 08-06-2009 02:13 AM ET (US)     Profile for ivansfo  Send Email to ivansfo
LHG, I don't agree zinc anodes are "less protective aftermarket (old fashioned, old technology)". What evidence is there supporting this claim?
I went with zinc because I want the least noble anode for my motors. According to metal charts I've seen, zinc is less noble than aluminum. I am counting on the zincs wearing out even fast than the original anodes. That's fine with me because I want the best protection and will to sacrifice some longevity. The Merc aluminum anodes may last longer but there is no evidence the Merc anodes offer more protection than zinc. I think they are just made to last longer and claim to be as good as zinc.
Though the Merc anodes worked fine for the first 4-5 years, I feel they did FAIL on me because my motors are showing signs of rust. If my motors were rust free, I may have more faith in Merc's anodes. So now I'm going to follow the advice of old salts and see how the zincs work out.
Remember...I use my boat in saltwater only. Everyone I have talked to says zinc will wear out fast in salt than fresh.
jimh posted 08-06-2009 02:41 PM ET (US)     Profile for jimh  Send Email to jimh
ZINC should offer more protection than ALUMINUM as a sacrificial anode. It is less noble. I suspect that the material to which LHG refers may be MAGNESIUM, which is less noble than ZINC.
The Mercury "Unobtanium" alloy is probably a trade secret or protected by dozens of unfiled patents, so we'll never know what's in it.
L H G posted 08-06-2009 04:25 PM ET (US)     Profile for L H G
I don't know what is in Mercury's formula. But I do know the new style anodes, circa 1991, don't last as long a aftermarket zinc, and hence give greater protection. This is what you want!
One season in FL, I had a West Marine "heavy" zinc trim tab on one engine, and a Merc "lightweight" trim tab on the other. After 6 mo in FL. the Merc anode was badly pitted and eroded, and the zinc one showed no erosion at all.
I have tried magnesium anodes in Freshwater only use, as recommended, and they also do not sacrifice as fast as the Mercury anodes do. Don't ask me why. I'm just giving you first hand information from extensive use of all three types, over 40 years of owning Mercury outobards.
I understand that Yamaha has also switched to some lightweight alloy for its anodes.
Does Evinrude still use zinc, or have they upgraded also?
jimh posted 08-06-2009 10:20 PM ET (US)     Profile for jimh  Send Email to jimh
I think it is a good idea to use the recommended OEM sacrificial anode. There is more to the prevention of galvanic corrosion that just the alloy. The best protection is a combination of the right amount of anode, the right location, and the right voltage potential between least- and most-noble metals. I'd stick with the recommended OEM anode. It can't cost much more, if any. You're protecting thousands of dollars of aluminum outboard. Why try to save $3 on the anode?
jimh posted 08-06-2009 10:29 PM ET (US)     Profile for jimh  Send Email to jimh
A fairly straightforward explanation of the principles involved in galvanic corrosion is given in
http://www.ceoe.udel.edu/seagrant/publications/corrosion.html
in which the author says, without reservation, regarding protecting other metals, that:
"In practice, and for reasons too complex to cover here, zinc works best."
L H G posted 08-06-2009 10:58 PM ET (US)     Profile for L H G
That poor guy is simply uninformed and not up to date. More waste of taxpayer dollars. Look at the old dates of his reference material. Besides, he is not talking strictly outboard engines and their special alloys of aluminum. He could learn a few things from Mercury, at least with respect to protecting outboards.
Take another look at invansfo's photos. That is what you call successful sacrificing. How many have zincs that look like that?
jimh posted 08-07-2009 06:19 PM ET (US)     Profile for jimh  Send Email to jimh
I don't think there has been much change in the physical chemistry of galvanic corrosion since 1980 that would render all previous scientific study of it obsolete or irrelevant.
I don't have any problem with using the OEM anode on a Mercury, but I need someone to explain to me:
--why I would want to use a Mercury anode on another brand, or
--why a Mercury anode is supposed to be superior to other OEM anodes, or
--why use of Zinc would be inferior to a Mercury anode on an electro-chemical basis. I don't need the marketing hype, just the electro-chemistry that makes Mercury better.
Again, because Mercury has had so much trouble with corrosion problems in their gear cases (such as the BRAVO III), it is no surprise that you need to use a number of sacrificial anodes with them and that those anodes work best if you use the specific Mercury parts. If I had an elaborate duo-prop BRAVO III gear case, I'd use the precise anodes specified by Mercury, you betcha.
seahorse posted 08-08-2009 09:07 AM ET (US)     Profile for seahorse  Send Email to seahorse
Larry,
That was about the same time that OMC started using aluminum anodes, too. I don't remember the exact year, though.
OMC said the same thing as Merc, the pure aluminum alloy protects better than the traditional zinc products. Part of the reason is the amount of contaminants in the zinc castings and smelting procedures compared to quick and cheap ceramic die-casting of the aluminum.
Gearcases and other aluminum cast engine parts are special alloys with traces of other metals for strength, machining ease, and other properties such as corrosion resistance. The anodes are a pure alloy that is less noble so it will sacrifice itself first.
I think evnironmental concerns raised the costs of zincs also and that is why many are made in different countries.
