posted 09-08-2009 11:37 AM ET (US)
I agree about not using dowels for filling holes.The leakage that you are seeing is not uncured resin from the repair. Spectrum Gel Coat Patch Paste in not a liquid. Even if you did not catalyze it all it will not leak out as described.
What you are seeing is moisture from within the hull, probably absorbed by the plywood of the transom from an improperly sealed screw from the old transducer. This is very common, almost ubiquitous among Whalers.
When you made the repair, the caulk did not perfectly bond with the wet surface it was applied to and an avenue of leakage was left behind.
The gel coat patch paste will not necessarily make a perfect water tight bond by itself every time.
Using 5200 is not a bad idea as a base...if you can get it to seal the hole, but you might try using some polyurethane glue (Gorilla Glue is one brand) to glue in plugs of wood that you can then seal.
Polyurethane glue will cure in the presence of moisture, in fact it needs water to cure. But if there is water weeping out of the transom when the glue is setting up, you may still end up with a leak.
The best time to seal the hole is when it is cooler outside. I have noticed that in warmer weather, or direct sunshine, a weep hole will be more productive on a Whaler hull. When it cools down, the weeping will stop.
Try plugging the hole in the evening and letting the glue cure overnight.
When plugging hole with wood plugs, I just cover a plug with glue and insert it into the hole that I have also coated with glue. If he depth requires another plug, just add it, keep inserting plugs until you have filled the hole.
Be sure to overfill the hole. Once the glue is cured, use a Forstner drill bit to drill back down to the depth of the transom;s plywood core. You now have a clean hole you can fill with epoxy or polyester resin. Gel coat over that, though in reality, if the hole is sealed properly, You *can* use Spectrum Gel Coat Patch Paste to fill the hole in one application.
