posted 09-13-2009 02:23 PM ET (US)
I kinda figure it's easier to ask you guys for help than to keep guessing. Here's the problem. Last fall I developed a sudden health problem and the boat and motor were stored inside until now with fuel in all the places where it had been when I turned it off before the heart problem. It was running fine when backed into storage by a friend. We pulled it out 9/11/09 and refilled the fuel tank (approximately 40 gallons in an 80 gallon tank. Charged up the batteries. Pumped up the primer bulb turned it on and let the beep do it's job and cranked it over to start it. Nothing! Cranked over strong but no start.
Figured it might be a low pressure electric pump problem and sure enough when we tested it it was stuck. Freed it up ( cleaned out the old fuel that had set up in it) and now it pumps fine. Checked the high pressure pump output located on top of the vapor separator tank ( took the hose off where the hose for the rails connect ) with the engine cranking over and no fuel / no pressure.
I kinda figured if it ain't pumping no fuel into the high pressure fuel hose then she ain't gonna crank.
Am I right or wrong? Where do I go from here? Thanks in advance and all help will be genuinely appreciated!
Milt
