posted 09-25-2009 11:45 AM ET (US)
You don't want BLUE smoke from the exhaust of your motor home - that indicates that you are burning oil. You don't generally want white smoke that dissapates (steam) as that indicates a cracked block that is letting cooling in.If your exhaust is emitting white smoke that doesn't dissapate, that is a 'normal' observation when using Sea Foam and/or fogging oil.
How long it will smoke is determined by a number of factors. The biggest question is how was the motor running before the sea foam application - i.e. why did you add it?
Because your exhaust system is very long and can contain a great deal of material (carbon) along it's length, it is possible that you will experienced prolonged smoking from treatment. Also, you may have a great deal more carbon build up if your motor home is powered by a diesel motor.
If it has been a long time (like, never) since your last sea foam application and you have many miles on the motor (and short trips), there could be a significant amount of carbon in the system and it will take multiple treatments to clear it out.
In general, I run sea foam in my truck once a year in the "middle tank" during a long trip when the engine is fully warm and I'm running at pretty good RPM for prolonged periods.
I run stabilizer/sea foam in my boat tank constantly as a fuel stabilizer, EXCEPT on long trips where I know I will quickly use the fuel that is in the tank.
