ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods Repair of Massive Cracks
Author | Topic: Repair of Massive Cracks |
fiberglass |
posted 10-24-2009 02:13 AM ET (US)
I just bought a 1963 Currituck 16. It has massive cracks all over it. How does one fix [massive cracks]? It also has a lot of holes on the deck from the old interior and other added junk that was removed and not pluged. I suspect it's waterlogged. If anyone out there can help I would be very greatful. |
mateobosch |
posted 10-24-2009 07:27 AM ET (US)
fiberglass,
Are you planning to do this restoration yourself or have it done by a shop? Either way, be prepared to get out the check book on this one. Do you have any pictures of the boat you could load on here?
floridaskater |
posted 10-24-2009 08:47 AM ET (US)
I did a 65 Nauset restoration. Re gel coated the entire hull, re did the wood, patched small holes in the blue deck. Also you will want to pull the brass drain tubes tip it and drain and dry it as much as possible. We even drilled some holes in the bottom to drain and used alcohol. You can only do soooo much though for water in foam. If you want contact me via email and I can tell you more of the story and send pics. Steve |
posted 10-24-2009 09:27 AM ET (US)
If your Boston Whaler Unibond hull has "massive cracks" they are probably serious structural flaws. Repair them according to the procedure described in http://continuouswave.com/whaler/reference/repairInstructions.html under the section "Structural Repairs." |
