posted 11-15-2009 03:17 AM ET (US)
CJ - I own a 25 Outrage with Armstrong bracket carrying twin 200 Merc EFI's. I had it designed and installed when the boat was new.First of all, don't expect too much bouyancy from the bracket. Not much of it is in the water with the boat at rest, so bouyancy effect is minimal. But I would not worry about that since the boat can easily handle the offset weight of a big single.
A transom bracket like an Armstrong is a surprisingly good addition to any cut transom boat 20' and over, and like you say, it makes for easy access to the stern. Armstrong also makes an excellent boarding ladder that drops into a notched fitting welded on to the bracket. Highly recommended.
My design recommendations for your project would be as follows:
1. design and install bracket for a 30" single engine, and use a dual engine design, but drilled for a single. The wider bracket body will give more floation, look better, and enclose the transom more effectively. It will also provide more bolting surface for load distribution on the transom. Side platform "wings" should be added to extend the overall width to the end of the raised portion of the outer transom.
2. Install the bracket on the cut transom so that the platform is 5" above the cut transom. This will give you effectively a 30" transom notch, greatly preventing water problems over the transom. The exposed face of the bracket (portion facing forward) will raise the "notch" 5" and keep water out. The higher power head provided by the 30" engine shaft length will be of value also. Almost all of Whaler's later 22 Guardians were built with 30" transoms. (They should have made this modification to the recreational 22's also, but never offered it.)
3. I would recommend a bracket setback of 26". 36" would be WAY TOO MUCH.
4. The 1" brass drain tubes in the transom may have to be glassed in for the bracket installation. An automatic 500 GPH bilge pump will have to be installed in the lower transom sump. The "D" transom eyes may not interfere with the bracket side platforms, since they will be 5" higher.
This bracket will be expensive, probably about 3K, but well worth it. You may be able to save money on the 30" engine, as dealers are often stuck with them and find them hard to sell. I would avoid the temptation to "cheap out" and go with a single engine narrow body bracket, and the 25" engine height. You will regret it, as the engine will be too low as you plane off the boat, and back down from plane.
Your installation will look very similar to mine, which is also designed for a 30" single, or 25" twins:
http://smg.photobucket.com/albums/v429/lgoltz/Outrage%2025/?action=view& current=7269006-R2-006-1A.jpg .
