ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Repairs/Mods NEWPORT: Adding Swim Ladder
Author | Topic: NEWPORT: Adding Swim Ladder |
macsfriended |
posted 12-16-2009 11:36 PM ET (US)
I’ve admired the Windline telescoping boarding ladders that I have seen on some later model years’ Boston Whalers. I found one at a bargain price and plan to install it on the transom of my 1976 Boston Whaler Newport (a pre swim platform design.) After looking at the wood placement diagrams on CW, I concluded there is no or insufficient wood inside the transom to firmly hold an occupied swim ladder at the preferred mounting spot. Sooo, I am thinking: 1. Bond a rectangular piece of one-half inch thick “starboard” or equivalent high tech marine structural board with a second piece aligned on the other side of the transom. These boards will have about a 3-inch larger footprint than the ladder’s mounting plates in both horizontal and vertical planes. 2. Drill through the two bonded boards and hull and attach the ladder with stainless steel bolts, nuts and washers. Appropriate 3M sealant / adhesive applied to the holes and all holes will be above the waterline. Candidly, not being an engineer, I want this to be over built and sounder than the unsinkable Titanic. Now, what have I overlooked?? What unintended consequences are looming to bite me, my grand plans and my beloved Whaler?? Your concerns and recommendations please. |
adlert |
posted 12-17-2009 09:20 AM ET (US)
macsfriended, I'll try to get some shots of my Montauk set-up to you this weekend. Needs re-varnishing (going with epoxy and clearcoat next time) but I'm still quite proud of it. I managed to attach a 3 step telescoping ladder UNDER the platform, giving me far superior boarding comfort and leaving the entire platform flat and usable whether the ladder was deployed or not. In my humble opinion, it's the way these sorts of platforms should have been made in the first place. Because the primary forces at play for the lower, outside mount that aligns with the wood-less section of the Montauk transom are against the hull, and to some degree downward, I decided I could afford to experiment with a less intrusive more conservative approach for that attachment point. I fashioned an appropriately sized teak block and simply glued it to the transom with 3m 4200. I cut the equivalent of a biscuit crevice into the face of the teak block (facing transom) to create a much larger 4200 plug within the block for maximum strength. Years later, hundreds of boardings and even quick take-offs with the ladder down and still no problems. Because the Montauk transom indents somewhat on the sides anyway, this solution also allowed me to properly align the swim platform with the rest of the boat. I think what you propose would work fine but if indeed you are talking about the lower brace mounting point, it's nice to not have to breach the inner and outer hull skins below or near the waterline. Feel free to shoot me an e-mail if I happen to forget. |
dscew |
posted 12-17-2009 09:30 AM ET (US)
Could you post a link to your photos here? I'm thinking the same thing for my 74 Whaler. Thanks |
adlert |
posted 12-17-2009 09:35 AM ET (US)
Will do my best. |
adlert |
posted 12-31-2009 12:15 PM ET (US)
Well, I've partially succeeded. Pictures have been taken and sent to macsfriended. I will try to set up a link to the photos soon but that's fairly new territory for me. dscrew, shoot me an e-mail and I can get them to you pronto. I assume macsfriended would also share. Tim |
adlert |
posted 12-31-2009 01:47 PM ET (US)
Sorry dscew, unitentionally misspelled your username. |
contender |
posted 12-31-2009 02:24 PM ET (US)
I would go to a ladder that you can mount and remove on the side of the boat at will, Two things you do not have to drill any holes in the transom (no leaks) second you only have to have it when you want to go swimming can be removed at will. |
macsfriended |
posted 01-01-2010 10:58 AM ET (US)
Thanks to all for their responses. And to adlert for his photos. All added to my knowledge base and supported my general intentions. Contender's thoughts are certainly good advice re keeping it simple and avoids the need to "pierce" the hull. I have seen many comments re the difficulties (and often impracticality) of retrieving a ladder that is stored aboard should the occupants "hit" the water unexpectedly without having riggesd a ladder while still aboard the boat. So I will use the transom mounted ladder that can ue easily extended for use by folks already in the water. Thanks again to all and Happy Whalering New Years. |
dscew |
posted 01-01-2010 11:10 AM ET (US)
I never saw the photos. Can you re-send them to me? |
adlert |
posted 01-01-2010 02:04 PM ET (US)
dscew, I'll be happy to if you'll supply me with an e-mail address. Your profile doesn't contain one. E-mail me via my profile address and I'll send them on. Tim |
dscew |
posted 01-01-2010 02:28 PM ET (US)
Sent you an email. Thanks! |
R T M |
posted 01-01-2010 05:23 PM ET (US)
mac. What are you using for brackets? Is the transom radiused or flat on your model boat? |
R T M |
posted 01-01-2010 06:52 PM ET (US)
Here are 7 pictures of the collapsable 2 step ladder I installed on my 13 footer last week. Of course I have yet to try in in the water, but I can climb into the boat from the garage floor easily. http://s27.photobucket.com/albums/c191/floridaboy2053/ladder/ I made the brackets myself out of 2 pieces of aluminum angle. The smaller angle is bolted to the larger angle so that the ladder will hang at an angle to facilitate climbing. A vertical ladder would be almost impossible to climb. The brackets are bolted through the transom with a large fender washer on the inside of the transom. rich/Binkie |
macsfriended |
posted 01-01-2010 08:23 PM ET (US)
Hi RTM As I mocked-up the ladder the transom in the mounting area appeared flat. The ladder model I purchased is designed for transom mounting (i.e. a vertical surface.) My intended assembly is: (from the rear moving towards the bow) 1. Ladder mounting plates. (Factory provided stainless steel) 2. “Starboard” 1/2 inch thick rectangular plate bonded to transom exterior with appropriate 3M adhesive. The “starboard” plate will exceed the footprint 3. Transom 4. Interior “Starboard” same as exterior plate and aligned with it. 5. All above are through bolted and secured with stainless steel bolts, locking washers and nuts. I just saw your 13' photos. Very good. I am aware of the potetial need to 'shim out" the lower brackets to aid climbers on the ladder and I expect to "do no drilling" until I have that worked out.
Ed |
R T M |
posted 01-02-2010 08:01 AM ET (US)
Ed, your ideas sound like good ones, I didn`t get the factory brackets when I bought my ladder at a marine garage sale, and I especially like the idea of starboard backing plates, but on the 13 footer with its radiused transom it would involve screwing the starboard to the boat and make more screw holes in the hull. I originally had in mind making a small swim platform and cut one out of mahogany, but then when it came to attaching it to the hull I realized I would have to fabricate two aluminum triangle shaped brackets with angles welded to the edges for attachment points, and would involve 8 more holes into the hull, so I scraped the idea. Here are some pictures of the platform. The store bought platforms use a piece of radiused stainless rail for the mounting structure, but I don`t have a pipe bender, and bending stainless into a rather tight bend is not easy with a hand operated pipe bender, even with the pipe filled with sand to prevent kinking. A store bought unit won`t work on a 13 footer. Contenders idea of a attachable side ladder will work for intended swimming, I have one that I had to modify for my 13 footer, and gave it away to my daughter, to use on her 13 footer. I wanted something that I could use if I fell overboard, so I could more easily get back aboard, as I am not as young as I used to be.
http://i27.photobucket.com/albums/c191/floridaboy2053/ladder/ladder9.jpg |
conch |
posted 01-02-2010 09:02 AM ET (US)
As Contender said a portable ladder that is only deployed when needed is nice. Most hoop style ladders for over the side do not fit properly. I purchased the small radius (hoop) ladder from West Marine and totally disassembled it.When new it easily comes apart. The two folding standoffs are in the wrong position for the 15 Sport. I drilled two new holes one step higher in the side rails for the standoffs and reassembled the ladder. A 180lb diver with full gear can board now without a problem and the ladder remains in the proper position. Chuck |
