Topic: Repair of Cracks In Engine Blocks Above The Freeze Plug
memory |
posted 12-19-2009 12:55 PM ET (US)
Can [a pre-mixed epoxy filler sold under the brand name Marine Tex be] used [to make repairs of cracks] on [an engine] block that is cracked above the freeze plug?
contender
posted 12-19-2009 02:48 PM ET (US)
You have nothing to lose, the block is cracked already, I can see two problems, when the engine is running the block with heat up and the crack will open/expand, and marine tex does not expand, Second The block will crack more thus defeating your patch...However, I have seen this done before on a crack, you drill a small hole at the end of the crack, all the way through (suppose to prevent it from spreading/ getting longer) then try your marine tex. The area must be clean and dry. The correct way would be to have it welded if it can be done...good luck |
tedious
posted 12-19-2009 03:02 PM ET (US)
Forget the Marine Tex - use JB Weld - that's what it's made for. |
Ridge Runner
posted 12-19-2009 04:02 PM ET (US)
I second JB Weld.
posted 12-19-2009 05:24 PM ET (US)
I do not understand the significance of the location of the crack as specified as being "above the freeze plug." Is there some significance to this location as compared to a crack in an engine block that is below the freeze plug?Marine Tex has a website that promotes their product, and it mentions many applications. I do not see any mention of use for repair of engine blocks. From that omission I would make the inference that the manufacturer does not recommend Marine Tex for repair of engine blocks, either above or below the freeze plug. |
Wasatch Whaler
posted 12-20-2009 10:40 AM ET (US)
You didn't mention what type of engine or what the block is cast from. So, It could be an outboard with an aluminum block, or a cast iron V-8 if an inboard.I have a friend who had a badly cracked (multiple cracks) MerCruiser 260 engine repaired by a company that specializes in casting repair. The before and after results were amazing, though commensurately priced. |
Plotman
posted 12-21-2009 09:13 AM ET (US)
JB Weld |
modenacart
posted 12-21-2009 04:56 PM ET (US)
You really should provide more information. Any recommendation at this point would be very premature. |
